Ammeter Setup not Behaving
+ More Options
Latest Activity
  • pentium
    replied
    Re: Ammeter Setup not Behaving
    This is over a year old but I'm going to wrap this thread up because someone linked me back to it when I was finishing this setup off today. Yeah, apparently it's that visible on google.
    Anyways, it was all completely wrong. The meters had the wrong windings, the current transformers did NOT need the single wind and as a matter of fact, one CT was completely dead.
    I ordered a new set of ammeters that shipped with matched 50/5 CT's (url=http://www.ebay.ca/itm/130894315346?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649]the listing if anyone is interested) so this time we were positive that it was going to work. When it arrived I found the meters were smaller than described (53mm x 53mm as opposed to the advertised 72mm x 72mm). Thankfully because the internals are identical down to the mounting points I was able to transfer the guts into the larger meter assembly at the expense the needle is shorter than it usually is.
    Now that we have it all assembled it works. I can do something like plug in my weller and I can see the current draw rise. I can spin up the 12" hard disk and the starting inrush surges to 35A before settling back down at 10A. I'm starting to regret using a 50A scale but it's going to cost too much now to replace everything so I'll live with it.
    This mystery is officially solved.
    replied
    You need to match the output of the CT with the scale of the meter. Using a resistor in parallel can help decrease the output of the CT, so you could overwind it, then reduce it with a resistor (or calibrate it with a pot.)
  • pentium
    replied
    Still not happy. Spent over a month fighting this and I'm still finding out I ahve to buy more crap to make it work.
    What you see is what happened. NO burden resistor was used.
    AC voltage out of the CT was ~.666v. Adding turns didn't change it much obviously but the amperage definately went up.
    replied
    That is great that you did not give up. I will ask my Chinese friend to translate that Chinese chart you have for the CT. By the way, did you use any burden resistor? and what AC voltage do you get on the CT output terminals?
  • pentium
    replied
    When written science fails, you shut the hell up and try practical.
    Tore out the basic components and tested various arrangements on my living room floor. Resistive load used was that 1500 12.5A space heater.
    During testing I could not use my DMM as the ammeter setting only works for DC, so I had to stick with "how big are the sparks"
    TEST 1
    Line was passed through the CT with one wind around the core. Ammeter was then attached directly to secondary terminals on top.
    (Note that the single wind is the red wire. Supporting the terminals on either side is a bakelite bar)
    RESULT:
    There was very miniscule needle movement, but nowhere near where it should be (12.5A)
    TEST 2
    Line was wired with the ammeter in series to the load.
    RESULT:
    Expected amperage was correctly measured.
    Okay, so I then had a suspicious feeling that perhaps the miniscule needle movement was in fact a reading of 1.2A. To test this I made five turns of the line around the core. In theory this would give me a reading half of what it really was.
    The result:
    I was correct.
    In the confusion of Ammeters being sold on ebay, somewhere along the lines a decimal point moved or something and in reality the meter was expecting a current ten times higher than could be delivered.
    ....Or a CT that was a tenth of what I needed was purchased...
    Off the top of my head because it is not feasable to make ten turns of heavy gauge insulated wire around the CT, the only solution short of getting more sensitive meters would be to increase the number of winds inside the meter?
    replied
    This is what I use, Simson AC A 1357 series Iron-Vane Direct connected (self contained) for up to six 15A load (resistive load) monitoring. For non-linear load, I use digital meter based on Psoc with True R.M.S. reading using 1000-turn Toroid CT for current sensing.
    It is too bad that OP gave up, he did nice job mounting all the parts and the chassis.
    replied
    "Just how do you know what the spec is? Those 50/75mV shunts are for DC moving coil meters, not iron vane ones!" The OP is the one that provide the spec which I had questioned him from the beginning, if you read the post from the beginning. The OP is the one that bought the meters, "For those who did not follow the other thread, I installed a 240V 40A branch panel in the house and for monitoring purposes I also installed a standard 200A KWH meter and two 50A 75mv shunt driven ammeters."
    "Why do you keep mentioning "the spec" when mismatched items were sold together when they shouldn't have been???" Well, why don't you ask the seller? read from the beginning of the thread. Look at the link he gave us on post 3. The seller have no idea what he is selling, may be even selling fake meter with wire jumped directly between the two terminals, never really know what you will get on EBAY. And so many had gave suggestions that so far, did not work so the OP left.
    "Instead of playing pissing contest, how 'bout you look at RODALCO2007's (youtube) videos. All kinds of stuff on CTs, meters, etc. Don't forget to dig down, 'cause you've only got that dumb "more videos" button."
    Did I insult you?
    Just read from the beginning of the thread.
    So far none of the suggestions had solved the problem. But if you insist on insulting people, go ahead, we are here to solve problems not to show how smart you are.
    By the way I do use lots of Current sensing coils, our own meter design in house in lots of our products, so do not assume some thing you do not know about.
    When people ask question about something they had purchased and cannot get it to work, we ask what the person bought, the spec, the info about them before trying to answer the question. What suggestion did you give him to find out if the meter is working or not? I did.
    "the loop as seen above replaces the bussbar with bakelire to support the terminals on either side so as it stands right now...
    Screw it. I give up. I have thrown all my knowledge at this and between all the chefs in the kitchen and as many photos and diagrams to explain what I have here NOTHING has worked.
    Reply if you want but I'm not coming back to this thread. I'm done."
    The bottom line? Did the OP get the meter to work the way he wants after buying so many parts to try?
  • kaboom
    replied
    Originally posted by budm
    "Look at it in the image above- just a coil=moving iron meter." We all saw that after 27 post later.
    So did you.
    We have no idea from the beginning if the meter is faked or actual working meter as advertised.
    The OP taking apart wasn't enough for you?
    The seller already got the money. too bad. If 75mV did not cause the meter to show full scale per spec,
    then there is no use to try it any further. If the meter is fed by simulated signal source as I suggested, we would have found out if the meter is working or not per spec.
    replied
    "Look at it in the image above- just a coil=moving iron meter." We all saw that after 27 post later. We have no idea from the beginning if the meter is faked or actual working meter as advertised. The seller already got the money. too bad. If 75mV did not cause the meter to show full scale per spec, then there is no use to try it any further. If the meter is fed by simulated signal source as I suggested, we would have found out if the meter is working or not per spec.
  • pentium
    replied
    You aren't allowing all the field around your wire to pass thru the window of the CT.
    Eliminate that bussbar and either loop your #4 or #6 around the core, or pass it straight thru, depending on the sensitivity required.
  • kaboom
    replied
    " Where the heck did everyone get the idea that there's a diode in there?!" Well we have no idea what is inside the meter that he bought, we are trying to find how the hell the seller is selling this meter and the shunt to use with the meter, so far it does not work as advertised and can see what is really inside this meter. I doubt that at this point if the meter is actually 50A/75mV full scale.
    Also:
    Originally posted by redwire
    I did some research, because when I worked in substations there are dozens of these meters and I never really paid attention to them... except when they read zero and it all hits the fan...
    The seller has an AC panel meter mixed with a DC shunt- together they will not work.
    The panel meter is a typical DIN 96mm used in the electrical utility industry, which has many standards to keep things compatible, so real specs (ohms, volts, amps) you will not find.
    From your pic, the symbols on the faceplate bottom left tell you the beast is: Moving Iron type, Accuracy Class 1.5 to DIN43780, vertical mount, dielectric strength 2.5kV AC
    Moving-iron meters work with AC or DC and I'm wrong about it needing rectifier diodes (moving coil meters need these)
    The standard to drive these is a 5A CT, although some meters are for 1A CT's. I'm not sure, your meter looks like a 50A scale one with overload room to 100A. I would try hook it up to a (split-core) 50/5A CT. In other words 50A gives 5A to the meter. A 100A CT with two turns feeding it, could also work.
    I'm not sure about the burden resistor. If it's in the meter, then no prob. - but without it it is easy to peg the meter playing around. Take an ohmeter reading on the meter (sans shunt), figure what makes it read full scale if you can.
    replied
  • kaboom
    replied
    Originally posted by pentium
    Perhaps you could draw this out for me? Here's essentially how it's setup right now:
    I'll be honest in that I'm getting super frustrated on this and keep getting told three different solutions, one of which constantly being "you should be using part X instead", only to find that doesn't work either.
    Your meter is fine. Where the heck did everyone get the idea that there's a diode in there?!
    The low resistance of the meter is fine. What you can do is put a regular DMM, set to current, in series with the CT and meter. The reading on the DMM should agree with that on the panel meter.
    Hope it helps...
  • pentium
    replied
    "Result is the needle moves but still nowhere near enough for the load."
    Try this do not use the shut that came with the unit and just loop the the wire instead and see if that make any different
    If that is the case then put one more loop through it and see if you get any closer to the right value
    you might need more than one loop it might be three if there is room
    replied
  • pentium
    replied
    Originally posted by tom66
    That's because you need an AC meter which has zero diode drop.
    I'm voiding my warranty to get a point across.
    There you have it. No diodes. Just a copper wire that does a few turns around the needle base.
    Anyways I went and redid the CT's with the single wind as the instructions showed so now they are installed as told from China.
    Not pretty but I'm not going for looks. Result is the needle moves but still nowhere near enough for the load. Perhaps the lack of a burden resistor is the issue?
    replied
  • pentium
    replied
    Yep. Back to this old thing again. :/
    So I removed the shunts and purchased two 50/5 current transformers along with some more wire to make up for the moving around of things in the cabinet. I used a brass bar to pass through the CT.
    Installation instructions (IS it correct? Most CT's just allow the line to pass through, plus the burden resistor) and another indecipherable piece of chinese.
    Save for the above change mentioned above (no single wind around the CT) the setup now looks like this:
    Again with just the space heater plugged in the CT outputs 0.67v of power.....and the needle doesn't move because if there's diodes in there it's only getting half the voltage it needs to activate the bridge. At this point here I'm sure either my issue is the lack of that single wind around the CT (fixable) or the lack of a burden resistor (what that chinese chart was for?)
  • pentium
    replied
    I still have some current clamps available.
    If you can beat $30 shipped for two I'm interested.
    0.5 Ohms does not sound right.
    If they are duds I can still replace them warranty.
    replied
    Acer ConceptD CN715-71P-75MV Notebook 7 Pro Specification for Upgrade or Repair
    This specification for the Acer ConceptD CN715-71P-75MV Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CN715-71P-75MV boardview and CN715-71P-75MV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
    09-06-2024, 02:30 PM
  • caspian
    Can Ammeter damage Power Supply?
    by caspian
    Dear Members,
    My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
    But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
    Is this true?
    I have attached the photo of a sample Ammeter module that I am going to buy....
    06-05-2022, 01:42 AM
  • hervou
    Philips PSU (715G7350-P01-000-002S) behaving funny
    by hervou
    I'm becoming crazy trying to fix the Philips TV of my old man (model 43PUS6201/12 - the TV, not my dad). I've read again and again discussions about this and similar TV models, on badcaps (thanks so much !). I see no other option than asking for your help.
    The symptom is simple : when I plug the power cord, the red "stand-by" LED does not light on anymore, and the TV powers-on neither with the remote control nor with the rear button. I guess at this point you immediately think at the 5V (or other voltage depending on the hardware) stand-by output......
    04-20-2024, 02:56 PM
  • caspian
    Conversion of Anolog Voltmeter into Ammeter
    by caspian
    Dear Members,
    I have an old analog voltmeter that can correctly measure DC voltage between 0v to 3v. The voltmeter is made by Toyokeiki depicted in the photos. It does not need any battery. It works using a coil and a magnet as any other analog voltmeters.
    I am going to convert this voltmeter into a DC ammeter that can measure DC current between 0A to 15A.
    To do this, I use a 0.2 Ohm resistor for current sensing in the circuit. Then, I use the setup depicted in the photo to measure current.
    For example, if the power be 12v and the load be 8 ohms, the voltmeter shows...
    06-25-2022, 07:13 AM
  • Comp_Pro
    No short but PPBUS_G3H missing 820-01700
    by Comp_Pro
    Hello all,
    I have this 820-01700 board which came in with 5V 0.015A on the ammeter. Ammeter cycles every 5 seconds or so. Upon inspection I found PPBUS_G3H is reading around 0.6V. There is no short to ground. Diode mode reading is about 0.420V. When I remove fuses F7000 and F7001 the U700 side of the circuit produces 12.3V and the cycling goes away on the ammeter but still stays at 5V and now reads 0A. This goes away as soon as I put back the fuses. I tried injecting voltage onto the system side of the fuse pads but I do not get any current draw at all. I tried seeing if the voltage...
    09-17-2024, 05:04 PM
