No sound HW C450
  • jpatrice22
    • Oct 2011
    • 39
    No sound HW C450
    Hi everybody,
    i've no sound and slow menu with Samsung HW-C450 sound bar.
    can sommeone help me to fix this issue please
    Thanks in advance!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: No sound HW C450
    Have you some good reason for double posting?
    It just wastes our time and effort.
    • jpatrice22
      • Oct 2011
      • 39
      i wasn't sure if i am in the good sections or not......as nobody replies me.....
        Can you post some pictures of inside of the unit?
        Slow menus could indicate a processor that is busy doing something else -- perhaps trying to initialise the sound but cannot do so.
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • LEECH666
          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
          by LEECH666
          Good day ladies and gentleman!
          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
          01-19-2024, 05:46 PM
        • Grasshopper2Ant
          Visio V755-G4 LED TV: No backlight, have sound, see menu with light.
          by Grasshopper2Ant
          No backlight issue. Have sound and can see menu with flashlight.
          Suspect LED driver, voltages are 100V each side. What should the voltages be for 75 inch TV on the Power Supply Board? I have 96 leds x3 volts per=288/2=144 volt per side?
          Am I low on my volts causing the leds not to light up?
          Before I got all backlights out, the right side was a bit darker than left side. How many leds
          need to be out for all to not work?
          Thinking of getting a led tester. If leds light up, would that confirm it is the Power Supply Board?
          I do not want...
          07-27-2023, 03:03 PM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
