Relay controlled PSU thermistor
    Re: Relay controlled PSU thermistor
    9V coil, 161 ohm resistor drops 13.7V.
    • Behemot
      • 4845
      • CZ
      Originally posted by TELVM
      Thanks for your efforts Behemot . Here, token of gratitude .
      I could use that at home
      What do you think that 161Ω resistor in series with the relay coil is for?
      Pretty much as tom says, some drop on resistor to bring the voltage down as relay is 12V rated.
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • nmbb
        Can not find Model/Value of Thermistor.
        by nmbb
        Machine: Autoclave.
        Brand/Model: SANYO MLS-3780
        Manual: (Sorry search option not working on this PDF)
        Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
        06-02-2022, 05:55 PM
      • CuriousJohn
        Burco boiler power problem
        by CuriousJohn
        Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
        Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
        This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
        12-22-2024, 10:25 AM
      • valvashon
        Repair Success! Middle Atlantic UPS2200R-IP
        by valvashon
        Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
        Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
        02-06-2024, 12:54 PM
      • ohren
        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
        by ohren
        Hello!
        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
        Measured voltages with no load:
        After rectifier diodes
        12V: 6.17 V
        5V: 5.67 V
        Secondary transformer pins AC measurement (really don't know if this says anything)
        12V: 2-2.5 V
        5V: 1.04 V
        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
        03-18-2023, 10:33 AM
