Blew Fuse on my GPS
  • newtoCaps101
    • Jul 2011
    • 93
    Blew Fuse on my GPS
    Fellas, Long time... I was trying to hard wire my navman ICN520 to my car, anyway I think I blew a fuse or something inside the unit or something. I stupidly cut the cigaret lighter adaptar cable in half and found 3 wires inside, Red, Black and White. So I used a ATX power supply and connected the Red and Black wire to the Yellow and Black on the power supply and it powered on for a second but then shorted and now the GPS although works it wont charge anymore.
    Can I fix it? I opened it up, not sure were the fuse is?
  • newtoCaps101
    • Jul 2011
    • 93
    Re: Blew Fuse on my GPS
    Okay, So I opened it up andon the Battery Pack there is 3 identical wires, Red, Black and White (Sensor). So assuming some micro transistor or something got fried that disabled the charging mechanism, Could I splice the 3 wires in the battery pack and then connect them directly to the Red, Black & White wires coming of the active power source(cigarette lighter)?
    Would that also charge the battery itself or will it blow up? Then do I need to cut off the battery pack entirely from the connector and then splice the wires to it?
      It will blow up, the Li-ion must be charged very carefully with real good charging current and voltage controller. Is the battery pack 3.6V?
      • newtoCaps101
        • Jul 2011
        • 93
        Yea, its around 3.6V. so any other ides / fixes for it? anyway i can repair its recharging mechanism or should i cut off the battery from the connector and hardwire the wires to the car power adapter that takes 12v and converts to 3.6v output??
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          the cigarette cord likely provided +5 to run and current limited 4.2v to charge.
          time to find what you let the smoke out of.
          • newtoCaps101
            • Jul 2011
            • 93
            How? everything inside is miniature and solid state. So no caps. Do I have a chance at repairing this or should I cut off the cable connector coming out of the battery and connect the identical wires coming out of the cigarette cord?
              There are many caps inside the units. There is lore likely and IC for the Li-ON Charging circuits. Not likely that you will be able to repair the charging circuits.
              MAXIM makes a lot of Li-on charging IC. You can learn more by Google LI-ION Charging. You can easily blow up the batteries and make nice big fire if you are not careful.
              • brispuss
                Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                by brispuss
                Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                12-28-2022, 02:58 AM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
                ACER Aspire AspireRevo R3600 + Gaming Pack Aspire 230 Specification for Upgrade or Repair
                This specification for the ACER Aspire AspireRevo R3600 + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire AspireRevo R3600 + Gaming Pack boardview and Aspire AspireRevo R3600 + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                09-12-2024, 03:28 PM
                MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
                This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                Acer Swift SF114-34-P6XJ + Pack Gold Notebook 1 Specification for Upgrade or Repair
                This specification for the Acer Swift SF114-34-P6XJ + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P6XJ + Pack Gold boardview and SF114-34-P6XJ + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                09-07-2024, 03:10 AM
