Need to wash a board
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hey, I'm working on my future mother-in-laws stereo. It just stopped playing, she said. I get output of the speakers when I plug into auxilary. When I switch the tuner to FM, I get nothing. When I switch to AM, I get nothing. No static or anything so I know it isn't the antenna.
    Anyway, I decided to rip it apart and much to my dismay, there was a mouse nest inside. I want to start testing various parts but it's real nasty. I vacuumed up most of it but I need to wash it. What's the best way of doing this without damaging the board? My father and I have a part washer for car parts. I was almost tempted to use that, however, I know that's not a smart idea. Is there anything like that for electronics or any liquids that would be safe to use such as rubbing alcohol?
    Thanks.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Need to wash a board
    warm slightly soapy water! let soak a bit then use a finger nail brush on it! tooth brush works too!
    • Spork Schivago
      • Mar 2012
      • 4734
      Thank you T.J.. The minerals in the water won't short out the connections after the water evaporates? We have hard water here because we live in the country and have a well.
      • t.j.
        • Apr 2010
        • 383
        • canada
        rinse with distilled or bottled water after! can take a hair drier to speed up drien process !
        • Spork Schivago
          • Mar 2012
          • 4734
          Okay, thank you very much. I will do this and go from there. Wish me luck, this thing is disgusting! I still haven't figured out how the mouse got in there!
          • ComputerGeek
            • Oct 2011
            • 262
            Yes if you rinse with distilled water you should be fine, I have washed a couple of boards and they have worked. I would not use the hair drier though, I would be concerned with the heat on the board and the Caps.
            • Spork Schivago
              • Mar 2012
              • 4734
              Okay, just out of curiosity, how much heat does it take to ruin a capacitor, in general? I got a heat gun and was thinking of getting some spare parts off of some broken electronics using it. Up till now, if I needed a part and didn't want to / couldn't order it, I'd just desolder it. I was thinking a heat gun would make it a lot quicker though {:- )
              • t.j.
                • Apr 2010
                • 383
                • canada
                dont over heat the board though! that is why i say hair drier! putting on heater vent with furnace running works too!
                • 999999999
                  • Sep 2006
                  • 774
                  There's probably no need to wash the board, merely dust off the heatsink unless it is highly visible through the top of the amp case so it looks disgusting.
                  What exactly does "I get output of the speakers when I plug into auxilary." mean?
                  It would be very difficult to damage the board, if they are smokers then spray some Mr. Clean or similar ammonia based cleaner on it and let it sit for a minute before rinsing. Otherwise plain warm detergent solution will suffice. No need to rinse with anything exotic, any tap water suitable for drinking is pure enough. No need to speed dry it either, just gently shake off excess water and set it on its side. However, a hair dryer held at a reasonable distance won't heat up the caps enough to matter, although if the amp is pretty old they might be degraded in performance already though if it still sounds good once the failure is repaired I would wait to recap unless it's a high value amp.
                  Most often an audio amp fails from either a blown fuse, diode, or output transistor. Trace the power and signal, power from the input and signal backwards from the output. Be careful when working with live circuits, do as much as you can before powering it up.
                  If you want to cannibalize caps off boards with a heat gun, get them off the board by heating the back of the board first, before other components. Otherwise with surface mount caps just be vigilant in pulling the cap off the moment you get the solder melted, not heating it any longer than that. Generally, capacitors are not rare or expensive enough that their reuse is a good idea unless reliability and performance doesn't matter, particularly when they are one of the shorter lived components in consumer electronics if they're electrolytic.
                  • t.j.
                    • Apr 2010
                    • 383
                    • canada
                    has mouse urine an feces on it! needs a wash!
                    • bluto
                      • Oct 2007
                      • 560
                      The cleaning motherboards thread might be useful here: https://www.badcaps.net/forum/showthread.php?t=1463
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        It's actually a stereo, not an amp. It's a Panasonic RX-C45 stereo.
                        When I have it set to tuner, on either AM or FM, there's no sound out of the speakers. Not even static. On the back of the stereo, there's some RCA plugs for me to hook the stereo up to an external source (like a CD player). When I hook something like a CD player up to the unit, the music comes out of the speakers. Also, I believe the tape deck works as well, but I haven't been able to test it because I have no tapes.
                        I will try the hair dryer after washing it.
                        Does this still hold true seeing how it isn't an AMP? Just the AM/FM isn't working. I figured it was something with the radio circuitry. I don't know much about this stuff, still learning.
                        Thanks.
                        Okay, around here, only place to get parts like that is from Radio Shack. They don't have a huge selection of components. I hate ordering them off the net. Can you suggest some of the more important components I might be interested in saving? Thanks.
                        Last edited by Spork Schivago; 09-24-2012, 07:45 PM. Reason: Changed my wording to make it sound more clearer
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Thanks Bluto! I had an idea from what others posted on how to do it. I like the fan idea overnight though. I'll do that.
                          • 999999999
                            • Sep 2006
                            • 774
                            I usually save stuff like through-hole ICs, heatsinks, transformers, maybe switches and various hardware... depends on what it is and if I have any of the component and how much it costs.
                            Digikey is a great place to order online, a wide selection and for orders under 8 ounces, an inexpensive USPS first class shipping option which for some small orders I place, usually comes in between $2 and $3 shipping cost and at least at my location, usually arrives on the 3rd business day after ordering. BIG improvement over years ago when they had a $5 small order fee and shipping started at roughly $7 and went up from there.
                            Thanks for explaining about the AM/FM, it does seem the tuner is suspect not any of the things I mentioned, although it could still be a power subcircuit going to it.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              I just recently ordered a film capacitor off of digikey. A snubber / safety cap on an amp needed replacing. The reason I don't normally order off of digikey is because I'm not 100% certain if the part I'm looking for is the same one on digikey. For example, my snubber cap wasn't on digikey. A forum member helped me find a replacement one on there. If it wasn't for him, I never would of found it. I searched as best I could for one, but some of the values in the filters are beyond my electronic understanding. A friend is supposed to be loaning me a book that explains the theory behind the electronics. I can build a circuit with schematics and replace broken parts, but actually understanding how it works is beyond me, right now. I wish I could find a digital copy of a book that would help me in the department.
                              • 999999999
                                • Sep 2006
                                • 774
                                http://www.google.com/search?q=learn+electronics+PDF
                                There's definitely a learning curve, start out memorizing things like component function, relevant parameters, and studying basic circuits then eventually it all starts to click into place and you'll want to build stuff and spend a lot of money on a personal component inventory. There are also a lot of online tutorials rather than PDFs.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Hey, I'm getting ready to wash this board but I got a few questions left. There's a part on the board, I'd call it the AM/FM tuner. It has a wheel on it and when you turn the wheel, it changes the frequency for the stations. There's also a volume pot and some slider switches. I can get all of those wet, right? I'm afraid that if I get them wet, water will get inside and stay there when I dry them out.
                                  • 999999999
                                    • Sep 2006
                                    • 774
                                    There are a couple of things to keep in mind. One, detergent solution is generally used to wash boards but it may degrade the grease on the mechanical portions of the tuner so they "might" need greased. For that matter the original grease may have hardened years ago and they might benefit from fresh grease either way.
                                    Second, yes you will get water in the little nooks and crannies that won't dry out fast. This is why the final rinse should have something in it to decrease the water surface tension so there aren't any drops sitting around later, that when you shake the board gently most of the water comes off. There are a few options like a drop or two of detergent, dishwasher rinse agent, (more than a couple drops of...) alcohol mixed in. If you have low enough surface tension the water will sheet off instead of forming drops on the board., which also gets it out of nooks and crannies better.
                                    It will need to sit in open air for a while to be sure everything is dry, pointing a fan at the board will reduce drying time. I'd leave a fan on it at least a day or a few days without a fan, but tapwater isn't especially conductive at low voltages so if they were slightly damp inside the remaining concern is corrosion of brass contacts in switches, pot sliders, etc. but being mechanical they should wipe themselves clean enough, brass doesn't corrode very fast/much in tap water. You might also consider spraying those with contact cleaner and turning or sliding them but I mean only the ones user controlled from the outside, do not turn the variable capacitors or other fine tuning that's not normally user accessible.
                                    However, some contact cleaners also displace water so using one that does would be the ideal... but not really necessary.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      Thanks. Does Radio Shack sell this contact cleaner? I might of moved the variable capacitor a very little bit the other day. That'll just make the displayed frequency off a little, right? For example, if the stereo shows the station on 95.1 FM, it might actually be on 95.6 FM.
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                      • howardc64
                                        by howardc64
                                        07-24-2025, 05:17 PM
                                      • edugimeno
                                        Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                        by edugimeno
                                        Hi!!
                                        Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                        I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                        At a certain point, moving stuff around, I put all wires back in place and...
                                        03-24-2024, 02:31 PM
                                        Tankless hot water heater controller board not powering up when power is applied
                                        I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                                        I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                                        However I would like to know if I could figure what happened to this controller board if possible
                                        Tomorrow I will take some better pictures of both side of both boards
                                        The...
                                        12-09-2022, 09:14 PM
