Help finding feedback transformer
+ More Options
Posts
  • Joun
    • Jul 2011
    • 191
    • Greece
    Hello
    I need help finding this transformer(the small one).It is from the feedback circuit of a 12V 30A power supply.The photo I'm attaching is from another SMPS but It is exactly the same..
    Thank you.
    Re: Help finding feedback transformer
    How many widings are there on this little guy?
    • Joun
      • Jul 2011
      • 191
      • Greece
      It is T2..
      • PeteS in CA
        • Aug 2005
        • 3579
        • USA, Unsure of Planet
        Blech! That is one wretchedly drawn schematic! I've figured out schematics before by looking at PCBs, so I know it isn't easy, but that is not very usable.
        Anyway, T2 in that P/S is not feedback. It's the transformer being used to provide base drive to the switch transistors. You would have to unwind it (very carefully!) to figure out what each winding is, and the polarity of the windings. And the details of the construction and the core type are all critical. Winding a new one would not be easy, and mistakes would not be obvious. Mistakes could do damage or be dangerous.
        PeteS in CA
        • Joun
          • Jul 2011
          • 191
          • Greece
          It know it is very bad drawn but it is the only one I could find in the net..
          Well I'm not going to unwind and wind it back that's for sure.The truth is I took that transformer from a smaller one and solder on this..
          I'm saying that I had to ruin a perfectly working 15V 5A in order to fix a 12V 30A.
          If there is not any other way I could find the transformer I'll leave it like this..
            M ay I ask on how you figure out that the transformer is bad? It is such too low power to burn up.
            • Joun
              • Jul 2011
              • 191
              • Greece
              The whole story goes like this:The power supply come to me with some kind of drink spilled in it(I think sourthen comfort or something like that)
              It had a blown fuse and a primary transistor burned,which I replaced and then I washed and dried the PCB.After that it wasn't blowning fuses any more but it didn't work.
              I had it open in my bench a few days and every now and then I checked a transistor or a diode ,measuring whatever I could think of but with no luck.
              I left at the very end this and primary transformers to check because they rarely go bad(especialy the small one)
              To my surprise there was one pin on the primary which was completely open,it didn't had any resistance with any other pin..
              Luckily I had a similar power supply(lower wattage and different voltage) which wad inside a identical transformer..I replaced it and it worked like new..
              It is a 12V 30A power supply,I tested it at 16A for a few hours and worked just fine..
              So I'm saying that it is exactly the same transformer regardless it was used in a different SMPS.
                Since you know that it has open winding, can you try unwrapping the tape to see if you can get access to see the broken wires, you have nothing to loose at this point. I do that on the transformers a lot of time when I have no other choices.
                • mikey5791
                  Is it possible for transformer substitution?
                  by mikey5791
                  Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                  Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                  My questions are
                  1. How do i test to see if the transformer is in good working condition?
                  2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                  Hope you guys understand what i was asking. My intention is...
                  11-03-2022, 02:11 AM
                • dennis_elx33
                  3PHASE STEP-DOWN Transformer in Check
                  by dennis_elx33
                  Hello All,
                  i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                  Problem statement: Power tripped Off
                  Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                  Action Done:
                  1) Replaced the faulty parts with good spare.
                  2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                  12-02-2024, 06:52 AM
                  ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 04:40 PM
                  ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 12:00 PM
                  ASUS Transformer T304UA-GN042T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                  This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 11:50 AM
