Almost there, finding the right cap for PSU.
  • littlejon
    • Aug 2012
    • 20
    • sweden
    Hi people, well after many days of researching, having known nothing about capacitors I see the light at the end of the tunnel.
    I'm replacing 2 caps in my TV psu unit but still a little confused about the ripple values and generally a bit confused.
    Here's what the reading is on the caps I'm replacing and the make (I think).
    (M)
    HC CE(M)
    105 C
    270UF
    400V
    Japan
    Now I have no idea what the correct ripple value should be on the replacement cap and what other values are important, from what I understand, getting a caps with a high ripple value is good.
    Is there anything else I should consider to be very impotent why buying replacement caps.
    I just need a little more info (I hope) before ordering.
    Any advise will be most appreciated. Jon.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Almost there, finding the right cap for PSU.
    Hi - is there some reason you are replacing this particular cap - bulging/damaged/leaking? Japanese caps are usually pretty good and this I am guessing is a Large cap which normally dont need replacing.
    A picture of it would help, though I guess someone will be along who can recognise it from the info given. If the (M) is a logo it may be instantly recognised.
    If you want to match the ESR and ripple values then you must identify the cap
    get the data sheet then match or better the values with the cap you buy as
    one the same may not be available. With large caps esr is not always stated
    - they are under less pressure than middle range caps so it is not so important.
    • littlejon
      • Aug 2012
      • 20
      • sweden
      Hi, yes I think the M could be the logo it's in a square box.
      I've just opened a thread in the PSU section, the problem I'm having is with my TV psu it's making a clicking noise under load (when brightness,colour etc is turned up) fine other wise
      Here's a link to another thread, the guy over there recommended changing these 2 caps, I have to say they look fine to me as do all of the caps on the board, the noise is coming from the inductor which is odd as it has no moving parts, take a peek if you have time I'm still a little on the fence about it:http://www.tv.quuq.org/forum/index.php?topic=6669.0
        [M] = Matshushita = Panasonic
        • littlejon
          • Aug 2012
          • 20
          • sweden
          Thanks again Tom, after looking at my posts do you think it's likely the PSU has a dodgy inductor?. I posted a reply..basically asking the best way to go about Varnishing the thing.
          • proxneo
            Recapping Sony ICF-SW55 - verifying cap values
            by proxneo
            Dear reader
            I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
            At the moment, I have selected replacements based on the following list of values:
            3 x 470uF 10VDC
            3 x 4.7uF 35VDC
            4 x 47uF 50VDC
            8 x 22uF 6.3 VDC
            1 x 220uF 6.3VDC
            5 x 100uF 6.3VDC
            Which...
            06-21-2023, 12:38 AM
          • rashidjafar
            Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
            by rashidjafar
            I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
            Values for :-
            PC43 : Capacitor [3x1.5mm]
            PL7 : Inductor [2x1mm]
            PC39 : Capacitor [1x0.5mm]
            Any ideas would be appreciated.
            I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
            08-07-2025, 05:10 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • Kobok
            Different (lower) resistor values on PCB?
            by Kobok
            Dear Alls,
            For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
            09-19-2022, 07:30 AM
          • DeXXter
            HP VICTUS 16-d0500la Some Values
            by DeXXter
            Here some measurements on HP Victus 16-d0500la, it might help someone, the values are on diode mode->mV and some lower ones on Resistance->Ω.
            This specific laptop has an Intel i5 11400h + RTX 3050TI, the values are from a working laptop....
            03-13-2025, 03:16 AM
