Can capacitor dielectric be black??
+ More Options
Posts
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    I've just opened a screen and looking round for the main filter capacitor in the SMPS I spotted this..
    I've taken it out of circuit, and it doesnt seem to hold any charge at all.. but the deposit on the top of the cap looks like glue or coolant, even though it must be dielectric.. What do you think?
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    Re: Can capacitor dielectric be black??
    Are you sure it isn't just the rubber bung they put on top of high voltage caps?
    • selldoor
      Slow Learner
      • 7870
      did you test in circuit as well? - care, high voltages.
      • JonathanAnon
        • Jul 2012
        • 457
        • Ireland
        This is the best pic I could get close up. The substance has a hollw, plastic feel.
        http://omg.wthax.org/small_1.jpg
        There is a small radial fuse blown on the AC input so I cant test in circuit... I've held it to a 9V battery and it doesnt hold any charge.. This same battery charges another large filter cap to 8.00v in a few seconds..
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          Just thinking about it there.. It doesnt make any sense for me to ask for any more help without peeling off the substance and having a look underneath.. So here it is..
          http://omg.wthax.org/thumb_without_rubber.jpg
          • mariushm
            • May 2011
            • 3799
            Yeah... change it... doesn't have to be 68uF if you can't find one... could probably go up to 120uF with no worries
            While the voltage rating could go as low as 350v, that's kind of risky... I'd say stay with 400v-450v rated caps.
            This should work: http://ie.farnell.com/panasonic/eeue...5mm/dp/1673496
            And this page has a selection of good caps... choose best mix of diameter / height + temperature rating you can afford: http://tinyurl.com/czn3pwg (farnell search page... short link because url was 500+ characters)
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              that cap has had it,the disk on the top stops anyone getting a shock,the aluminium case is usualy at mains potential.
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • JonathanAnon
                • Jul 2012
                • 457
                • Ireland
                Yeah, I see that now.. I'd never seen those rubber tops before.. I guess what happened was that when the cap blew it seemed to melt the rubber top and made me think it was dielectric...
                Gonna buy a new fuse and a new cap. Just wondering if the blown filter cap lead to the blown fuse, or perhaps a failure somewhere else along the line lead to the blowing of both the fuse and the filter cap...
                • b700029
                  Banned
                  • Sep 2010
                  • 640
                  Probably the cap failed shorted, causing it to vent and blow the fuse.
                  With the cap out of the circuit, ensure the primary is not shorted.
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    yeah,as b700029 says,the cap has shorted out causing the fuse to blow,when you put in the new filter cap,just ohm out the fuse terminals,it should show open circuit or very very high resistance,and to be safe,connect a 100w light bulb across the fuse terminals and power on,should glow bright then off or very dim,if it does that then your safe to put the fuse in and away you go
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      Yeah I read this in a book, but havent had the opportunity to try it yet... It's a great idea. I was gonna try it before putting in the fuse.. btw, that's a fast blow fuse isnt it? I've found two identical fuses on the radionics site, but there's nothing I can see to identify F or T ..
                      Hopefully by the middle of this week I'll have myself a nice working PC/TV screen for less than ten euros... (and you know how little euros are worth these days :-) )
                      • b700029
                        Banned
                        • Sep 2010
                        • 640
                        T = time delay.
                        http://www.sourcingmap.com/t315a-315...aign=usfroogle
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          It appears that the vent has burst on the cap and melted some plastic.
                          Crappy "chang" caps! Replace the ones in the secondary too!
                          Hopefully the s/c capacitor didn't blow anything else! (besides the fuse)
                          Muh-soggy-knee
                            Looks like a Vestel PSU these were notorious a few years back for having fake primary caps which shorted after some time.
                              master hoarder
                              • May 2008
                              • 12170
                              • Bulgaria
                              Interesting.
                              I always though the common failure mode for those high voltage caps is open circuit rather than short circuit.
                              O/P should definitely check the main MOSFET for short circuit and the Source resistor for open circuit. That way, if more parts are bad, it can be all ordered at once.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Originally posted by momaka
                                Interesting.
                                Crap-caps love to go short-circuit and draw excess current
                                Muh-soggy-knee
                                • JonathanAnon
                                  • Jul 2012
                                  • 457
                                  • Ireland
                                  I have them ordered, so put your chips on the table please.. :-)
                                  I have a 400v 150uF cap. Could I use this instead.. I thought the higher the capacitance the better the filter job it would do?
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Sure you can, as long as it has enough space!
                                    Muh-soggy-knee
                                    • JonathanAnon
                                      • Jul 2012
                                      • 457
                                      • Ireland
                                      See, I picked up an old XBOX today (which has a 400V 150uF cap), having already ordered the 400V 68uF cap and the 3.25A fuse from radionics. They should be here on Friday.
                                      The 400v 150uf cap is certainly way too big for the TV, it's wayyyyyyyy too tall. But it would have worked as a nice test before I made the purchase.. I could throw it in place of the 68uF cap and put a 60W bulb in place of the fuse... I might just try it anyway..
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        If you don't have a spare 3.25A fuse, just use a 3A to 2A fuse to test it. One thing is for certain, NEVER put in a bigger size fuse!
                                        Muh-soggy-knee
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                          MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                                          This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 01:58 PM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LG gram 16Z90P-K.AA85A1 16GB_512GB - Black boardview and LG gram 16Z90P-K.AA85A1 16GB_512GB - Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-07-2024, 03:40 AM
