Capacitance Measurements
  • tieny
    • Feb 2012
    • 478
    I recently just bought the peak atlas ESR70 meter.
    When a capacitor starts to go bad, does the capacitance usually measure higher than the specs? I measured a variety of capacitors and all measure usually a bit under the spec.
    However some I actually measured higher than the spec. would that mean its beginning to be bad?
    I measured a budging 470uf and got an esr reading of 0.3 ohms but a capacitance reading of 680uf.
    Usually when a capacitor goes bad the ESR increases greatly.
    Also when would it be considered a bad capacitor, like what percent would the capacitance be off from relative to the factory specs?
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Capacitance Measurements
    capacitance will usually go higher,normally the measurement should be +-20%,make sure also you use the probe compensation to make sure its calibrated on the esr70.
    0.3 esr is a good value for that cap,but still the cap could be out of tolerance.
    i have this meter and has never let me down.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      Sacon FZ revival experiment
      by momaka
      So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
      https://www.badcaps.net/forum/showpo...&postcount=548
      … and here:
      https://www.badcaps.net/forum/showpo...&postcount=585
      … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
      The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?...
      01-26-2022, 08:43 PM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • dougg3
      Faytech FT0150TM touchscreen turning on and off - fixed
      by dougg3
      I've been dealing with this 15" touchscreen monitor from the early 2010s. Over time, it has become more and more difficult to power on. As soon as a video signal comes in, the Faytech logo appears on the screen and then it goes black. Then a couple of seconds later the Faytech logo comes back up on the screen and it goes black again. This process repeats over and over again. Eventually if I leave it on long enough, the video display finally comes up and it works fine. The longer I leave it turned off, the longer it will boot loop before working correctly again. I tried a different AC adapter...
      02-03-2024, 03:04 PM
    • mkdj
      MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
      by mkdj
      About me, my goal and the equipment I (don't) have:
      I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
      About my issue and my goal:
      A friend of mine has a MacBook Air M1 A2337 that does not...
      04-03-2025, 08:28 AM
    • Info13
      Dell H235P-00 Power Supply Failure
      by Info13
      A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
      After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
      ➡️ First test:
      The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
      A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
      I then followed the advice from the forum and replaced...
      10-22-2025, 01:52 PM
