Help ID a sot-23 device
+ More Options
Posts
  • theagent
    • Mar 2011
    • 27
    Hi. I was hoping someone could help identify this component.
    I'm trying to repair an xbox wireless racing wheel that someone had plugged a random power adapter into and blew. The wheel would not power on. I saw damage to this sot23 component and an smd tantalum cap... I replaced the cap and the device powered on... however it powered on by itself, and the middle button which functions as both a power button and menu button wouldn't work properly. It also would not power itself off as it should. My conclusion was that it was this sot23 component for obvious reasons (giant hole).
    There's obviously damage to it, so I couldn't make out the marking perfectly...
    At first I thought it was a SI2301/A1SHB... so I originally replaced it with one of those. The device didn't power itself on by itself, however when I press the power button it only lights up for a millisecond.
    Looking more closely at the device I didn't see a lower case s with a line, but rather an upper case S... so I did some more research.
    A bit of searching had me believe it was a BAW56 dual diode. Since the markings start with A1. To test whether it was I connected two 1N4148 diodes according to the BAW56 schematic... but no luck. It wouldn't turn on at all at this point. I'm not sure if this would be a correct way to test a BAW56 component... aren't these simply 2 switching diodes anyway?
    So if anyone could help, I'd really appreciate it.
    Here's a picture of the sot23 component... and one of the board.
    https://www.dropbox.com/s/5jy9pl7ahp1jsob/SOT23.jpg
    https://www.dropbox.com/s/4ha2cgdg5x...wheelboard.jpg
    The cap I replaced was EC3, and the sot23 component is Q3.
    Thanks very much.
  • kikkoman
    • Jul 2007
    • 691
    Re: Help ID a sot-23 device
    I'd say since they label diodes as D and ICs as U, you probably have got a transistor there. could be a FET too but usually you see BJTs for gen. purposes.
    If you can tell if it's on the high or low side (any of its pins @ ground or at Vcc?)
    this is the basic idea: http://ikalogic.cluster006.ovh.net/w...ads/swtch1.jpg
    hope it helps.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • theagent
      • Mar 2011
      • 27
      Thanks for the reply. I'm not too experienced... can you tell me how I would test that? From the base to ground I get 23ohms, from base to vcc 0.9ohms, and from vcc to ground I get 23ohms as well. Setting my multimeter to the diode setting I get 0.001V base to ground, and 0.020V base to vcc, and 0.020V with vcc to ground. I get this result regardless of the orientation of the probes (pos to base or neg to base). And it beeps continually, as if it's shorted (and it probably is).
        That transistor can be 2SA1XXX (Japanese SEMICONDUCTOR P/N system), which will be PNP type. On your pictures of the transistor, the left pin will be base, the middle pin (stick up to the top) is Collector, the pin to the right is Emitter.
        Can you take the DC voltage reading with black probe of the meter to the Ground (right terminal of CA9 as shown in your picture), the red probe to each pin of the transistor, report what you read on each pin, unit must be powered up. By the way, your transistor is shorted out, it may be uesed as a switch to supply the votage to the circuits, when the TANTALUM failed (Tantalum CAP usually fail in shorted mode, when it failed it shorted out) shorted, so it take out the transistor with it isne the transistor will try to feed the voltage into shorted out circuits.
        • theagent
          • Mar 2011
          • 27
          Ok, just soldered it back on and took the readings...
          Looks like they're fairly similar at each pin.
          ~3.580V on the base, ~3.650V emitter, and ~3.555V collector. Thanks.
            I mean to test the voltage with it removed, since it was shorted out and you had already remove it to take the picture, I just need to find out the voltage at each pads without the transistor.
            • theagent
              • Mar 2011
              • 27
              Oops... ok, desoldered it and tested the pads.
              I have ~4.056V for the Base (left), ~4.253 for the emitter (right), and 0V for the Collector (middle/top). Of course the unit wouldn't power on without the transistor in place, but the batteries were inserted, so there was voltage to it.
                OK, it is an PNP transistor since B+ is fed into the Emitter, so you just have to get PNP transistor with Vce of about 50V, Ic of about 500mA (or 300) SOT-23 footprint. Do you have any scrap board with SMD components? They just use this transistor as a switch, since it has shorted Emitter to Collector then you can not turn it off.
                One more thing to verify is that the Collector is connected to that Tantalum cap or not, it should be if I am correct.
                • theagent
                  • Mar 2011
                  • 27
                  Ok, great! Thank you for the help, I really appreciate it. I do have scrap boards. I will have to go through them and see if I can find one that will work. I will report back Thanks again.
                    Please read my edit post on the last statement.
                    • theagent
                      • Mar 2011
                      • 27
                      Seems to be connected yes. The left side of EC3 is connected to the collector with 640ohm between them. No connection to any pins of the transistor from the right side of the cap.
                        Hmm, I expect it to be direct connection from the Collector to the cap since it is supplying the voltage to the cap, if the 640 Ohm is in SERIES with the cap leg and the Collector, that does not make sense.
                        • theagent
                          • Mar 2011
                          • 27
                          It's actually behaving very oddly. Setting the meter to ohms, it is now jumping up to about 20Mohms, then quickly falling to about 500kOhms then 0L, then jumps right back up in the megaohms, and repeats. That's with the probes on the right side of the cap, and on the collector.
                          Here's the breakdown.
                          Meter set to Ohms.
                          Probe on right side of EC3
                          Probe on Collector
                          Jumps to 20-23Mohms, then falls quickly to 500Kohms, then 0L and repeats
                          Probe on base
                          1.36Mohms, then slowly falls
                          Probe on emitter
                          rises until it reaches 6.23Kohms... then stops.
                          So, looks like the cap is charging, then draining.
                          Probe on LEFT side of EC3
                          Probe on collector
                          1.452Kohm
                          Probe on base
                          Climbs from ~500ish Kohms
                          Probe on emitter
                          Climbs until it reaches 6.153kOhms then stops.
                            OK, I look at the picture, the left side of the EC3 is connected to the Ground plain, the right side of EC3 is connected to U1 (Regulator) middle pin, so EC3 is not fed by the transistor.
                            The Collector looks like it is connected to the Anode of D8, and also to the top pin of U8.
                            So I wonder now if U1 is OK. You may want to check the left pin and the middle pin (as oriented as shown in the picture) to see what voltage you are getting from left pin to ground and middle pin to ground.
                            • theagent
                              • Mar 2011
                              • 27
                              Thank you for taking the time. I'm getting a steady 0.103V from all 4 pins of U1. Do you still think Q3 is a PNP transistor? I believe I found one I can try... it's 45V 500mA bipolar... do you believe that would work?
                              • theagent
                                • Mar 2011
                                • 27
                                Well, I went ahead and tried the PNP transistor. It didn't work. No lights, nada. The only other time the wheel lit up was when I used the SI2301 mosfet, but like I said, only for a millisecond.
                                  so the transistor has shorted between Emitter and Collector, so when you put it in, the unit comes on but cannot turn off, which make sense, but when you put in the PNP, it does not turn on, so it may mean that the transistor is not being bias on. So you need to put red probe on the Emitter and the black probe on the Base, it should show 0.6V if it is being turn on.
                                  • theagent
                                    • Mar 2011
                                    • 27
                                    With the red probe on Emitter and black on Base, it's showing 0V unfortunately.
                                      Ok, it is being told to turn on.
                                      I look real close at the picture again, I see the two pads labeled with 'BATTER' and one of pad's trace leads directly to Emitter of Q3, it is also connected to the bottom leg of R1 but I cannot tell if the top leg is connected to, C1 is also connected to that trace. I can also see right side of R2 is connected to the Base. Am I corrected? It sure looks like this Q3 is a switched transistor.
                                      I wish the picture is better focused and brighter.
                                      • theagent
                                        • Mar 2011
                                        • 27
                                        I traced out what I thought was important... would this help? https://www.dropbox.com/s/535l3gv1b9...oardtraces.jpg
                                        It's the battery that's connected... the line that says +5v is for the power adapter, which isn't connected.
                                        I also ran the board through Adobe Lightroom and brightened it up quite a bit. https://www.dropbox.com/s/6qqhxomi93...oardBRIGHT.jpg
                                        • Nevillet
                                          Identifying a 'FS45' SOT23 device
                                          by Nevillet
                                          Hi All,
                                          I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
                                          Its named FS45 but I can't find a datasheet that seems correct.
                                          The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
                                          Can anyone identify the device and suggest an alternative?
                                          Many thanks.
                                          PS: I have...
                                          06-19-2024, 11:42 AM
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • kjells
                                          Need help identifying a SOT23 device labeled WAW
                                          by kjells
                                          I have problem identifying a SOT23 SMD device. It is labeled WAW. I know this is a diode, possibly a zener. Device is part of the gate driver logic in a switch mode PSU. Anyone that can help me with this issue.. Thanks.
                                          10-08-2023, 06:28 AM
                                        • kjells
                                          Need help identifying a SOT23-5 device labeled as 72 2B 06 in tree different rows
                                          by kjells
                                          I have a problem identifying a SMD device. This is likely a SOT23-5 package, and it is labeled as 72 2B 06 in tree different rows. See also attached picture. Device is part of the gate driver logic in a switch mode PSU.
                                          Anyone that can help me with this issue.. Thanks....
                                          10-07-2023, 01:38 PM
                                        • Yolofolkss
                                          Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
                                          by Yolofolkss
                                          Hi this is a really odd case.
                                          I have removed all of the esd ic for USB 3.0 and 2.0
                                          I measured all of the data lines and 5v usb voltage lines there are no shorts
                                          all of the USB ports have no damage
                                          Clearing the bios using the jumper wont help.
                                          it is still showing USB overcurrent device
                                          the only temporary fix I've tried and worked so far is flashing the bios
                                          and the error is gone
                                          but when you start the motherboard with a USB device still attached
                                          the USB over current device error is back. the bios needs to be externally flashed...
                                          01-09-2023, 04:21 AM
