I have problem identifying a SOT23 SMD device. It is labeled WAW. I know this is a diode, possibly a zener. Device is part of the gate driver logic in a switch mode PSU. Anyone that can help me with this issue.. Thanks.
Need help identifying a SOT23 device labeled WAW
Re: Need help identifying a SOT23 device
Added "labeled WAW" to thread title
Post some pictures,and post the PSU model number/PCB model.
.Last edited by SMDFlea; 10-08-2023, 10:52 AM. -
Re: Need help identifying a SOT23 device labeled WAW
PMEG4010EJ -- SBR, 40V, 1A, Vf=0.54V(1A), 43pF
https://www.mouser.com/datasheet/2/9...EJ-3081607.pdf
Edit: Sorry, wrong package.
Edit #2.
See https://smd.yooneed.one/code5741.htmlComment
Thank you for the reply.PMEG4010EJ -- SBR, 40V, 1A, Vf=0.54V(1A), 43pF
Edit #2.
I think I finally found it myself.
The correct way is to read as %AW, the first letter being a placeholder for manufacturing site.
This gives us a Nexperia PMEG4010ET, single schottky in a SOT23 package.Comment
by kjellsI have a problem identifying a SMD device. This is likely a SOT23-5 package, and it is labeled as 72 2B 06 in tree different rows. See also attached picture. Device is part of the gate driver logic in a switch mode PSU.
Anyone that can help me with this issue.. Thanks.... -
by NevilletHi All,
I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
Its named FS45 but I can't find a datasheet that seems correct.
The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
Can anyone identify the device and suggest an alternative?
Many thanks.
PS: I have...5 Photos -
by NilssenHi,
As topic sais, i need help identifying a SOT23 NPN transistor.
Marking on the transistor is labeled 6CE, will try uploding a picture. -
by kjchatmanthis laptop was damaged by a roof leak at the repair shop that it was at while waiting for a replacement cpu fan. It was given to me to try to save the motherboard which wouldn't power up anymore. The only issue now is that an sot23 marked R1 is missing one of it's three legs. I cannot find schematics for this model but I found a mosfet that has the same label but i'm not sure if it's an actual match. CJ3401 is the one that I found but I have no clue about the true identity of the damaged one.
by NevilletHi All,
I'm trying to repair a swich mode PSU and have found a shorted TO220 device but cannot track it down.
The markings are:
First
15T43
FIR7N65AF
A picture is attached.
Many thanks....1 Photo - Loading...
