A 555 timer, a mosfet, some inductors and diodes = dead PC fans.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    So, over the last couple days I have been again tinkering with my 555 timer based mosfet driver. This time I decided to see what would happen if I attached the drain pin of my mosfet in between a random ferrite donut connected to V+ and a SB560 Schottky diode hooked to a simple 120mm .46 amp rated computer box fan.
    I set the frequency of the 555 timer's oscillator to around 25khz, turned down the duty cycle all the way via my voltage divider trimpot, set my resistance to around 18k going into pin 7 and hit the switch.
    Amazingly the voltage on my output shot up from the ~9.35V out of my 2.5 amp rated SMPS wall wart to around 10.5v. Adjusting the duty cycle up resulted in a final output voltage of around 22v at which point the fan broke free from what I had propping it up from the force of the air it was moving. When the fan hit it got something on my desk caught up in the blades breaking one off. With the fan stopped the open circuit voltage shot up to around 68 volts.
    I quickly proceeded to hit the oh shit cutoff button I rigged on my breadboard since my output caps were only rated at 50v. Luckily nothing blew up. A second attempt at driving another cheap recycled fan resulted in me achieving 30v with no signs of the toroid having reached its saturation point.
    Still not satisfied, I fished around in my transformer pile and dug out a small 4 pin transformer maybe around the size of an ATX PSU 5v standby transfomer, just shorter and more rectangular. Realizing exactly the potential these things have from my donut experiences I decided to change my output filtering caps to a couple 200v caps also scavenged out of a PSU. Also, if the output of transformer went high enough I had to take precautions to protect myself from anything blowing up.
    The idea was to use the transformer as a flyback. To do this I decided it would be best to rectify the output of the transformer into a capacitor and measure the voltage. I ended up using a BYV26C ultrafast sinterglass avalanche diode with a reverse breakdown voltage of 600v and reverse recovery time of 30ns as my rectifier, a .68uF nonpolarized 400v rated film capacitor as my tank, a 200v rated p6ke200 zener/transient diode connected to the positive pin in parallel with a beefy 180k resistor to safely bleed down the cap upon turning off the power or in the even the output of the transformer went overvoltage.
    With my driver again turned all the way down I fired it up. ~750mv. Crap. Ok so I must have hooked it up to the primary... lets try it the other way around. Bingo... 100+ volts. So far so good... I remembered somewhere that SMPS transformers can be like wound and polarity biased so I reversed the output leads at which time I found out exactly what the little beast was capable of... imagine that 200+ volts out of a 9v PSU!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: A 555 timer, a mosfet, some inductors and diodes = dead PC fans.
    Been thru that phase myself, but you'll quickly find out that you can't get any significant current out of such a setup, and it won't be as fun anymore. Sure it's good for charging caps but that's about all it can do.
    12v fans will work fine up to 26-28 volts.
    A working TV? How boring!
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      With a transformer with enough windings, the right rectifiers, the right filter caps and enough insulation in the right places you can transform volts into kilovolts pretty "easily". Of course, a smoke-generator/light-dimmer is even easier.
      PeteS in CA
      • Evil Lurker
        Warranty Voider
        • Feb 2011
        • 454
        Heheh one step ahead of you. Took an old monitor flyback, wrapped 10 turns around the core for a new primary, turned the juice on and... not much of anything. Reversed wires, getting a nice inch and a half plasma stream coming out the end of the HV lead.
        Mosfet is heating up like a sumbitch... had to put a bigger heatsink on it and add a fan.
        Gimme less plasma, bigger spark... dunno what I should do though.
        Anyways, I love the smell of ozone in the morning.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          To make sparks instead of arcs you would need a voltage multiplier. Unfortunately all modern flybacks already include HV rectifier diodes and it's impossible to take them out, and you need AC to feed a multiplier, so you'd have to wind your own transformer.
          • JayPoorJay
            Hot Water Rad - A Few ECU Fans and a Timer Switch
            by JayPoorJay
            Good Afternoon, Good People.
            I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
            I REALLY would appreciate y'alls help.
            This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
            10-29-2024, 12:54 PM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • Wolf1977
            general question when a mosfet on primary of transformer is burned
            by Wolf1977
            hi
            in a welding machine i had a mosfet and four components wich connect with it burned
            i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
            i dont understand whats happen wrong
            more particular on the schematic q11p01 mosfet q11p02 tranzistor
            three paralel resistors had burned q11p07 zener shunt q11p08 open
            when i changed all these shunts q11po7 mosfet and tranzistors
            maby the transformer has problem on your opinion or something on...
            08-19-2023, 01:27 PM
          • emil_t
            RTX3090 working fine but fans not spinning
            by emil_t
            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
            04-12-2024, 06:54 AM
          • Nooy
            VGA MOSfet permanently shorted and loss of MOSfet pad
            by Nooy
            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
            02-14-2024, 02:26 AM
