RF Switch!
  • adrianl
    • Aug 2010
    • 5
    Re: RF Switch!
    I've often wanted a way to do something similar. In an ideal world there would be a reasonable priced remodulator to move the channel 3 signal to another carrier then you could combine them easily. Not all that different than what cable companies do to put a single digital premium channel like HBO in the the analog channel plan for hotels.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: RF Switch!
      Originally posted by ivtec
      today i dicovered that this video switch also does Rf conversion,i though it did not work i was using a rf converter connected to it.
      That isn't a basic switch as you said you were looking for.
      Nor is it what I suggested to modify.
      You could still achieve what you actually asked for with that by bypassing or removing the modulation circuitry.
      Basically gut it except for the switch board and install your RF connectors.
      Mann-Made Global Warming.
      - Dr Seuss
      • ivtec
        • Dec 2008
        • 1967
        Re: RF Switch!
        It's not what i wanted but I'm better off with this one than before cause i can add 1 VCR RCA, my FTA\OTA HD satellite RCA inputs, 1 pc RCA inputs and 1 of the 2 sat RF inputs coming from downstairs connected to where it says Antenna in,of course have to push buttons,the rest i keep a 3 way SW to change between OTA Analog that i have in other room coming to where i have the Signal amp and distribution Switch and other inputs,and this confusing set up will work much better. thanks for all of you that tried to help.
        • bluto
          • Oct 2007
          • 560
          Re: RF Switch!
          You are basically describing an RF demodulator. One that takes an RF channel and converts it to composite + L/R audio output.
          http://www.smarthome.com/77605/Multi-Channel-Tuner-Demodulator-NM-Tuner/p.aspx
          Or an old VCR could do essentially the same thing. Then you can take the signal and feed it back into whatever.
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Re: RF Switch!
            It's better to just start with line level signals and modulate them wherever you want them.
            That's a sloppy, roundabout way to do things. Use a cable box w/o line outs, take it's RF output, demod/remod it. Depending on the rolloff of the mod and demod, you'll lose sharpness.
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • bluto
              • Oct 2007
              • 560
              #26
              Re: RF Switch!
              I never said it was the best way. Only that it is possible/the product exists. That seems to be the theme in this thread anyway.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: RF Switch!
                When you're all done you discover this plan is a PITA because when you want to switch inputs on one of the TV's you have to go to another room.
                Also everyone has to watch the same thing.
                - Dr Seuss
                • ivtec
                  • Dec 2008
                  • 1967
                  Re: RF Switch!
                  This one is a RF demodulator that converts RCA and S Video to Coaxial RF and also have one RF antenna in and one RF out to TV.
                  i know that's not the best setup but i don't want to loose RF quality for the money it's the best i can come up with and there is better but costs much money
                  https://www.badcaps.net/forum/showthread.php?t=18544
                  • ivtec
                    • Dec 2008
                    • 1967
                    Re: RF Switch!
                    Why should i remove the modulation circuit? i can connect at least five RCA or S Video and one Coaxial RF cable and send all to one cable to the amp then to all other TVs with no expense at all of course I'd like something like some people sugested professional demodulator, but the set up will cost about 300 ucks,when i asked for your opinion or advise i did not know that this RF a manual demodulator that i put up pic of, in the previous post was working, i was using it as more of a RCA,and Svideo to connect 1 sat and the Laptop RCA out to other tvs in the house, i got this manual modulator in the flee market for 5 bucks with no transformer i had to get a 6dc tran.and change the 6 volt input connector on the back cause there was no transformer with that so small output connector.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: RF Switch!
                      To make it an RF Switch -- which is what you originally asked for and the title of the thread.
                      That Modulator is probably PAL or NTSC and good for nothing else.
                      [That's why the newer ones cost more money.]
                      You''l be fine as long as all your stuff is old and works at that level.
                      Good quality, you probably won't have it.
                      Those things are for a TV right next to them and they rarely put out enough power to run a whole house distribution with multiple sets.
                      - An amp and filters should still be used for the remote TVs but attaching the local TV right off the amp might overload that TV's RF amp.
                      Use the filters anyway.
                      You don't want reflected signals bouncing between the RF sections of the different TV's through your network.
                      Frankly you'd be better off sending everything [except satellite] to a PC [as a media server] and putting in local HTPC's [basic simple play-only versions] next to each TV.
                      At the very least the resulting wiring wouldn't be a rats nest. [sorry RD]
                      - Dr Seuss
                      • ivtec
                        • Dec 2008
                        • 1967
                        Re: RF Switch!
                        You're right all my stuff is still old i have a Sony Kv36HS500 and i love it,
                        Connected to it i Have Sat/OtaHDNFUSION receiver with outstanding HD pic.
                        also connected to the Sony Tv an A analog Sat with 36'' DISH with motor,a VCR, A DVD a Home theater system, also have 2 coaxial cables coming from downstairs from my brother in law Dish net. connected to the 2 Rf inputs.And from that on for the rest of the house have 10 RCA CTC series all analog but great Pic.
                        • bluto
                          • Oct 2007
                          • 560
                          #32
                          Re: RF Switch!
                          I still don't see why you wouldn't want a UHF modulator system on at least some of your sources. One of these bad boys would get you 3 in-house channels right off the bat:
                          http://www.ebay.com/itm/New-Channel-...item1c23045dfc
                          So with two of these and two of the above demods for the E* rf feeds you could have all your sources on 6 in-house UHF channels that could be tuned independently on all of your 10 TVs downstream. I assume that you have all 10 already linked up with coax and a distro amp of some sort.
                            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 05:30 AM
                          • Natob82
                            Micro Momentary Push Switch?
                            by Natob82
                            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                            12-21-2022, 05:22 AM
                          • grimacelord
                            NEC TurboExpress On/Off Power Switch Replacement Help
                            by grimacelord
                            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                            11-09-2023, 09:49 AM
                          • SluggerB
                            Help making a switch work the opposite way with a relay
                            by SluggerB
                            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                            02-07-2025, 07:57 PM
                            ACER Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP Veriton 820 Specification for Upgrade or Repair
                            This specification for the ACER Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP boardview and Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                            09-12-2024, 03:36 PM
