Can a capacitor have low ESR and still be bad?
  • amelbye
    • 46
    • Norway
    I'm wondering, because I just swapped out a bunch of high ESR caps from a power supply, and the unit went from faulty to dead...
    I checked the ESR on all the parts I put in (didn't have enough new parts around, so I took some from a project I've given up on)
    Could it be that some of the replacement capacitors have other problems that doesn't affect their ESR readings?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Can a capacitor have low ESR and still be bad?
    If a cap is shorted it will read low ESR.
    The way to tell is to also check DC resistance with a DMM.
    If it reads low on both it's a shorted cap.
    Most caps won't have to be pulled to check resistance.
    Only need to pull the ones that read low to make sure it's not a parallel resistance issue.
    If they read high in circuit they will still read high out of circuit.
    Also check that you didn't make a solder bridge or a cold joint somewhere.
    Mann-Made Global Warming.
    - Dr Seuss
    • b700029
      Banned
      • Sep 2010
      • 640
      The capacitance could also be too low.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5084
        • New Zealand
        What was the original fault?
        Do you know what ESR value the old capacitors _should_ have been? If your new ones had ESR much lower compared to what the originals had when they were brand new that can also cause issues.
        (Though I believe that the PSU will still work in such a case, but you will get worse ripple than there should be)
        -David VanHorn
        • 999999999
          • Sep 2006
          • 774
          How do you define "faulty" as it was previously? Were the caps visibly vented? I am wondering if you simply caught a PSU fault in its early stages and the existing damage got worse. Electronics like to do that the *next* time they're cold powered on.
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • harp
            high voltage high resistance marking resistor
            by harp
            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
            08-26-2024, 01:42 PM
          • cind12
            GTX 1080 TI Gigabyte Aorus low resistance on vmem
            by cind12
            Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
            Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
            The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
            Resistance on 12V 4K ohms (Power present when on)
            Resistance on 12V PEX 4K ohms...
            12-08-2023, 09:09 AM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
