Have i got the right Cap
  • Panzerlancer
    • Nov 2011
    Hello, this is my first post so ill try and cram as much info in as possible
    I am a complete noob to all this.
    A capacitor on a sewing machine power board has blown, it was a nichicon PT(m) with a 250v/150uf rating.
    i have bought a capacitor its a nichicon VZ(m) with a 250V/150uf rating.
    can i use this to replace the other ???
  • mariushm
    • May 2011
    • 3799
    Re: Have i got the right Cap
    As far as I know, there's no 150uF value in the VZ series.
    VZ:
    PT:
    So you may have a fake or some old capacitor that's no longer listed in the new pdf files.
    Other than that... generally these high voltage/low uf ones don't fail so often and don't have such hard to match specifications and they don't run at high frequencies, so it should be ok.
    • Panzerlancer
      • Nov 2011
      wow i didnt know it was such a cut neck sorta world (fakery)
      err here is the ebay link have a look yaself
      http://www.ebay.co.uk/itm/150uF-250V...item3a684eec67
      Dont hate me for being a newb lol
      iu suppose i should have known better than to buy off ebay
      • mariushm
        • May 2011
        • 3799
        I don't know what the say... the ones on the eBay picture are supposed to be made in 2009, based on the code on them. They could be custom made for a company but I doubt it.
        Compare to these : http://i.imgur.com/UYuAV.jpg
        The nichicon font is a bit bolder and maybe less tall, letters and number are closer together, the top is usually a + while on the picture it looks more like a Y... but it could be different on the ones rated for higher voltage due to much more room to print stuff.
        PS. you can go for the ones rated for 400v or something between 250v-400v, if they're easier to find at low price.
        • Scenic
          o.O
          • Sep 2007
          • 2640
          the ebay ones are fakes. Nichicons with triangle vents on top? no way.
          Also showing a totally generic bag that doesn't look like what nichicon uses at all.
          if it has to be ebay..
          http://cgi.ebay.co.uk/250743625793 (if it fits.. snap in type)
          http://cgi.ebay.co.uk/120783888535 (same as above)
          http://cgi.ebay.co.uk/300532998401 (??? generic pic.. who knows what you'll get, but at least it's a normal radial cap)
          http://cgi.ebay.co.uk/290451400827 (short leads. will not work if cap lays parallel to the board)
          http://cgi.ebay.co.uk/300574108333 (if you have too much money on hand)
          otherwise, check electronics stores listed in the "where can i get replacement capacitors" thread
          United Kingdom - Digikey - http://uk.digikey.com/
          United Kingdom - Farnell - http://uk.farnell.com/
          United Kingdom - RS Components - http://rswww.com/
          keep the uF the same, voltage the same or higher (350-450V is easier to get, but check the can size!)
          • DrewPhillips
            Capacitor Diarrhea - Nichicon PL Series
            by DrewPhillips
            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
            03-02-2025, 10:18 PM
          • nick3092
            Mid/late 80's Nichicon Yellow Caps
            by nick3092
            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
            08-28-2022, 03:56 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • Eh546
            Polk PSW125 capacitors choices for a beginner.
            by Eh546
            I was looking to repair my Polk PSW125 subwoofer plate amplifier, i've checked around the web and it seems to be a capacitors problem.
            Took apart the amp, and made a visual inspection, everything's seems fine, fuse ect no burn marks, but i noticed 3 caps that were a little bit bulged. One 400v 150uf, one 50v 47uf, and two 63v 47uf.
            I noted each caps voltages and uf anyways, and made a list on digikey. Some recommended Nichicon and Panasonics ones (FR and FM) serie. So I tried to stay with the Panasonics FM-A serie.
            I would like to know if the caps i selected...
            12-21-2023, 07:28 PM
          • chth96
            Is there datasheet for nichicon LXJ series?
            by chth96
            I want to calculate capacitor ESR referring to below guide.
            https://forum.digikey.com/t/calculat...-from-tan/2633
            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
            11-20-2022, 08:11 AM
