OST RLS what to replace with?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Got a motherboard here that doesn't turn on, when she told me she turned it off at the end of the night and it wouldn't turn on again in the morning, it sounded like a bad psu. But changing out the psu with a known working one, the board still doesn't turn on, at all, the fan doesn't spin or anything, just no life.
    I suspect a shorted bad cap.
    The board is littered with TK, OST and G-LUXON.
    I ran across the board with my DMM and came across one which appears to be shorted .5 ohms on the 200 setting, I haven't confirmed it by taking it out to test again.
    Anyways having trouble finding a replacement
    I need two types.
    1000uf 6.3v
    ESR .72
    Ripple 760
    8x11mm or 12, I can go to 14
    and
    220uf 16v
    ESR 0.13
    Ripple 405
    6x11mm
    both are RLS and temps are 105 Celsius.
  • mariushm
    • May 2011
    • 3799
    Re: OST RLS what to replace with?
    Are you really restricted in height? Seems strange to have this issue on a motherboard.
    If you can go to 15mm high, you have some options:
    http://search.digikey.com/us/en/prod...PD6-ND/2428118
    Otherwise, if you really have height problems, you can probably go with polymer caps... and slightly lower capacitance values should work. For example:
    http://search.digikey.com/us/en/prod...3-1-ND/2347911
    http://search.digikey.com/us/en/prod...111-ND/1662497
    If you really can't find one, I'd suggest to keep in mind that the tolerance for these capacitors is 20% so just maybe you could get by with a capacitor rated for a lower value.
    For example, Panasonic FM/FR series are known to usually have slightly higher capacitance value than the one listed so maybe you can get by with a 820uF capacitor that if you're lucky, will probably give you 850-900uF in reality.
    220uF:
    http://search.digikey.com/us/en/prod...393-ND/2433527
    http://search.digikey.com/us/en/prod...2920-ND/762830
    • c_hegge
      • Sep 2009
      • 5219
      I'd be using https://www.badcaps.net/store/produc...roducts_id=131
      That's the same height as the original
      For the 220uF, https://www.badcaps.net/store/produc...roducts_id=112 would probably work
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        220uF:
        Well about 3 out of 8 is restricted due to PCI and PCI-e slots might cause clearance issues with video card and other add-ins.
        I looked at HM, I feel that ESR is too low and might cause issues, but maybe my understanding of ESR is incorrect. Anyone want to confirm?
        RS 220 cap's ripple is too low, ESR is double then what RLS.
        • c_hegge
          • Sep 2009
          • 5219
          I've used them to replace RLS on motherboards lots of times and it's never been a problem.
          You'll probably have to get the 220uF caps from digikey then. They would probably have the HMs as well.
          • yyonline
            • Jul 2009
            • 692
            I've used HM-grade capacitors to replace RLS spec capacitors. I've never had any issues.
            Use Panasonic FR or FM for the 220 uF.
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              So much for recapping this board.
              I got all the caps I need and today tried to recap this board and it's just a no-go.
              I spent two hours trying to remove first cap, during that time I did my normal routine *tin the iron, apply solder to old solder, wiggle cap out.*
              I broke the lead off, used two irons one 25w and one 40w, burned off the track but still tested ok I think.. can't tell. After an hour, I got it out. Got the new one in, solder it back. Went to the second one, it came out but I couldn't punch a hole with a pin through the back-filled hole. Change tips with a new one, that didn't work. Max my setting to 850F, that didn't work either. Check my iron with high temp thermometer it reads 900F at the tip, so iron tip is at max temp. Then tried a heat gun, pre-heat the board and kept trying, eventually I got the pin through but the hole was not big enough.
              At this point I just said fuck it, not worth it.
              Old solder has poor heat transfer or something, maybe it's not solder.
              This is an HP board and putting in the board number RC415ST-HM brings up the HP specs but also ECS specs too.
              Anyone know what ECS uses for solder?
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • chth96
                Can I replace KME cap with Samxon GF cap?
                by chth96
                Hello.
                I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                04-17-2024, 07:11 AM
              • JohnsonJ
                Allen&Heath XONE92 DJ mixer repair
                by JohnsonJ
                Hello everyone.
                I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
                The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
                12-12-2020, 11:19 AM
              • Antonynl
                What are typical ripple voltages on a laptop motherboard?
                by Antonynl
                I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                So I have two questions:
                1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                12-09-2022, 06:51 AM
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
