I have this PCB mounted fuse, RV16F, which measures 4.7 ohms on my ohmmeter test. It's on the 230V input to a device. The device draws less than 100mA, so I figure this is unlikely to cause a problem, but it's still a very high resistance for a fuse, or is it?
Fuse marking RV16F
Re: Fuse marking RV16F
Try measuring with another meter. I'd expect zero ohms, maybe just a few tenths for the leadsSystem: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
In fact it probably is your leads. Short them together and you will get 'value A' - then measure accross fuse for 'value B'. Subtract A from B to give C = resistance (if any) of fuse.System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
Originally posted by dumpystig View PostIn fact it probably is your leads. Short them together and you will get 'value A' - then measure accross fuse for 'value B'. Subtract A from B to give C = resistance (if any) of fuse.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yeah that's OK with the leads then. I wouldn't worry too much about the fuse reading, it may even be a fusible resistor which are often found in circuit designs.System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
