Evaluate High uF Capacitors
  • Longbow
    • Jun 2011
    • 623
    Here's a question for those interested in older linear mode power supplies. For many years computer grade power supplies used gigantic electrolytics to stabilize the power rails to logic boards (usually with TTL and ECL chips). Nobody designs circuits with these parts anymore, but let's say we want to evaluate an older 50,000 uF filter cap. These caps were designed to filter 120 cycle pulses riding on a dc level of 5-50 volts depending on the circuit. Other than an open or shorted part, what kind of testing would be used on monster sized filter caps?
    Is it plugged in?
  • berniedd
    • Mar 2007
    • 119
    Re: Evaluate High uF Capacitors
    Capacitance value, I would think. But how to go about it, I'm not sure. I don't know of any commercial equipment that measures that high.
    • Jack Crow
      It's a CLASOB!
      • May 2008
      • 823
      Long Bow,
      I suppose we could go back to basics.
      Do a charge / discharge cycle into a known load resistor.
      That will tell you if the value of the cap is close to spec.
      Very often the best way is to sub in a good part for the suspect part and see what happens.
      Jack Crow.
      "You are, what you do, when it counts"
      The Masso
      "Gravity, the quickest way down"
      Mayor John Almafi
      "You ever drop an egg, and on the floor you see it break?
      You go and get a mop so you can clean up your mistake.
      But did you ever stop to ponder why we know it's true?
      If you drop a broken egg you will not get an egg that's new?"
      MC Hawking
      • P4C800
        ASUS P5A and P2B-S recapping. Searching old datasheets.
        by P4C800
        I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
        There are three mainboards:
        - ASUS P5A rev 1.04
        - ASUS P2B-S rev 1.03 "Rubycon"
        - ASUS P2B-S rev 1.03 "Chemi-Con"
        If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
        They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
        P5A
        10-09-2023, 05:55 AM
      • ithe
        Online UPS input 220VAC high cut - low cut filter PCB troubleshoot.
        by ithe
        This online UPS is not detecting Mains 220V AC input, by observation I found a SMD Capacitor (C6 which responsible to operate the relay next to R27) is burnt in 220VAC high cut - low cut filtering PCB.
        Please share me a suitable capacitor value for this circuit.
        Thanks...
        07-19-2024, 01:59 PM
      • Califauna
        Help with boom box modification
        by Califauna
        Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
        I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
        From factory the specs of the boom box are:
        -Power Input: DC 5V
        -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
        -Drivers:
        -2 x Woofer, 70mm, 10Ω, 70mm,15W
        -2 X Tweeter, 8Ω, 30mm,10W x 2
        -Frequency...
        12-04-2021, 01:53 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • dragon3x
        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
        by dragon3x
        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
        power on.
        Here are some examples :
        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
        switching supply area).
        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
        than 6.3 V.)
        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
        I replaced capacitors with aluminum-polymer.
        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
        03-21-2025, 02:46 PM
