Has anyone actually made a capacitor?
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    I don't mean one of those jar ones, or the ones where you make a massive thing using cling-film and it ends up storing 1pF or something. I mean an actual canister shaped one. Now I know these usually require big machines and great precision but I was wondering if anyone made one as proof of concept.
    Come on, even a homemade one is better than a GSC.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Has anyone actually made a capacitor?
    You missed the thread about wooden capacitors didn't ya...
    Mann-Made Global Warming.
    - Dr Seuss
    • Rulycat
      • Apr 2010
      • 724
      • United Kingdom
      That wasn't proper science though, that was just bellendery...
      • mockingbird
        • Dec 2008
        • 5488
        The manufacturers state the basic science behind it... The ridges in the aluminium relate to the voltage, and the electrolyte defines the characteristics... But they don't give you any specifics, so I imagine that it would take a good bit of reverse-engineering to make one.
        • Rulycat
          • Apr 2010
          • 724
          • United Kingdom
          It'd be quite cool to make a basic one in the same shape (but bigger) and refine it from there. But I think the main problem would be longevity from impurities in the metal as well as dust introduced in the inevitably non-clean room environment.
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • Agent24
            Dick Smith Q-1760 linear power supply filter capacitor question
            by Agent24
            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
            It has at least one problem.
            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
            I have already ordered a replacement potentiometer, so that's not an issue.
            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
            All are CapXon...
            10-21-2025, 05:39 PM
          • chth96
            If I replace with inferior capacitor, Is it No harm to other IC components at all?
            by chth96
            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
            I know that these capacitor will not last as long as nichicon capacitor...
            12-22-2023, 04:34 AM
          • chth96
            How can I test non-polarized capacitor?
            by chth96
            I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
            I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
            And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
            I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
            06-02-2024, 07:31 PM
