Got a tripp lite UPS. Not sure of the exact model, possibly an Omnismart 1400 (it does not say anywhere on it). Was given to me because it would not power on. After prying out the 3 12 volt 7 amp batteries (quite swollen and dead), I opened it up and checked it for bad caps, scorching, blown chips, cold solder joints, blown surface mounted fuses, etc. The board is clean of all that. Checked it for voltage from the circuit breaker on the back (check). Started checking for fuses on the only Circuit board, found 2 - 25 amp, 1 - 7.5 amp, and 1 - 2 amp fuse All soldered into the board. All checked good except the 2 amp. Had to go down to the local auto parts store to get a replacement. Installed the fuse. Powered it on and..... Nothing, no power.
Can post pics but they may not help much with the mess of wires coming off the top of it.
Also I never finished my electronics class in high school so...
Any Ideas?
Any Ideas?
