Is it my soldering equipment too or just me?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Is it my soldering equipment too or just me?
    the reason i don't like motor oil or grease is that the oil is a bit thick and is not safe for rubber.
    Natural Rubber - yes. Petroleum will screw them up fast.
    - But most o-rings are synthetic rubber now and some are fine [or even designed for] oil and grease.
    Buna N [aka Nitrile or NBR which = Nitrile Butadiene Rubber] for example is a synthetic rubber o-ring material formulated specifically for petroleum based applications. It's also used to make oil seals and gaskets.
    There are other synthetic rubbers that suck as bad as natural rubber for petroleum compatibility.
    - There are so many different materials you just have to look compatibility up to be sure.
    The Navy 'o-ring tech manual' [the real name doesn't make sense] was 861 pages when I had to learn it and know all of it. Some asshole asked me the # pages on an oral board when I was qualifying as a QA Inspector for Trident Subs. Amazing how I still remember the # of pages but forgot 99+% of the content. - It doesn't even cover the multiple Mil-Specs for O-rings. It references them but they are in other books.
    Mann-Made Global Warming.
    - Dr Seuss
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by Wolvenmoon
      On my radio shack one...I have lost the manual and there is not one online. Anyone else have one of them and know how to get at the back end of it to check the seals there? (Previous sentence added after the rest of the post was typed. I decided to give it a hard twist because 'what they hey, it's broken already' and pop! I still can't figure out how to get the tip out of it though.)
      I think mine may have been DOA, as it is pre-lubed and still has this issue. I'm thinking I'm just going to replace it with something else.
      This has to be one of the coolest discussions I've been in in awhile though. Most places I get 'one right answer', here I'm getting 5 different workable answers.
      Ratdude, do keep your mind out of the gutter. We cannot let a discussion about the proper lubrication and sealing of liquified metal pump suckers' O-rings and pistons turn dirty.
      if you want another get one like mine...
      i know it needs some work to make it good, but it is better than ratshack:
      1. it has 2 o rings on the piston. not one. they also are thicker.
      2. all aluminum body and tip holder. i have had anything less (half plastic, half metal or all plastic) explode in my face.
      3. easier to work with... the metal ring around the button is all that holds the back half together... it does a good job and when you need to do work back there, it is easy to get out with pliers.
      4. replacemnt tips available (i need to replace mine...)
      at a local electronics store, I pais $5 for it. dirt cheap if you ask me.
      sigpic
      (Insert witty quote here)
      • Wolvenmoon
        • Jun 2011
        • 9
        That's exactly what mine looks like, but mine has a plastic top half.
        I suppose cheap plastic tools are more of a risk to eyes than boiling flux/flux fumes. lol.
        • smason
          • 1652
          I've been using the same one of these http://www.hmcelectronics.com/cgi-bi...ss.cgi?i=DS017
          since about 1985, have replaced one tip, and lubed the O ring once a year or so. Still works amazing, plastic or not....
          • Agent24
            I see dead caps
            • Oct 2007
            • 4950
            • New Zealand
            Mine is very similar to Ratdude's, but without the surround by the release button.
            I am on my second tip as I somehow managed to stand on the first and snap it in half, but I think it needed a new one anyway.
            After a couple of years I thought the spring had lost tension, turned out it just needed lubrication, I sprayed a bit of WD40 in it and it works like new again!
            (Not sure if that's what you should use, but it worked)
            -David VanHorn
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • Geeker007
              Friend messed up my laptop motherboard while working on my bench
              by Geeker007
              Hi All,
              So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
              So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
              I have not tried putting...
              06-16-2025, 01:40 PM
            • tony359
              Kaiweets USB soldering iron
              by tony359
              I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
              As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
              In other words, do you think it's expected and...
              02-06-2024, 12:51 PM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • Mattz_GT
              Which caps to replace: ECS P4M800Pro-M V1.0A
              by Mattz_GT
              It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
              I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
              Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
              Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
              PS. Additional diagnostic,...
              01-22-2025, 12:12 PM
