Polymer Caps
  • RoTTe
    • Feb 2006
    Polymer Caps
    Hi! I need some help. What is the diference between polymer caps and normal aluminum caps? the low ESR? or other factor?. I need recap some PCB's and I have some problems with the polymer caps (the shipping cost). I have thought about use normal caps, double the capacity or use two normal caps in parallel (divide the ESR). Some suggestion? Thanks.
    Sorry Bad Einglish :P
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Polymer Caps
    polymer capacitors use a solid polymer electrolyte unlike normal al e-caps which use liquid electrolyte. The benefit is very low esr and high ripple current.
    you may replace polymer capacitors with normal low esr aluminimum capacitors and it is recommended to replace with about 2x the value of the polymer caps. if the circuit needs similar low esr you must replace with very low esr caps like rubycon mcz etc.
    many designer specify polymer caps like oscon etc.... in many case this quality of capacitor is not necessary
    please more information about your pcb to help you further
    • gonzo0815
      • Feb 2006
      • 1600
      Re: Polymer Caps
      If possible you should figure out the real ripple current, the caps are exposed to.
      The problem is, that some oscons are rated for ripple currents up to about 9A. Even the best elktrolytics woudlnt stand that high currents for long. So i suggest look how many phases the pcb or vrm unit has. if there only 2 phases and outputcurrents are higher than about 40 to 50 A (e.g AMD Athlon xp) the ripple current for the input caps could be as high than a quarter of the outputcurrent. Most elektrolytic are rated between 1 to 4 Amps.
      On the outpusection things arn`t that bad, there an replacement with equal esr would be sufficient. Another point is the heat. In small server casses there are in many cases higher temperature, if proper cooling isn`t there. Again, the oscons are better suited for high temps.
      • arneson
        • Sep 2005
        • 1267
        Re: Polymer Caps
        Is size a factor ? Specifically height?
        More capacitance, higher working voltage and temp, in a smaller package is a winning combo.
        Jim
        • Perry Babin
          How do organic polymer caps compare to liquid electrolytic for reliability
          by Perry Babin
          I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
          If not organic polymer, what would be the caps that could take the most abuse?
          08-18-2025, 04:04 PM
        • SwedishDiesel
          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
          by SwedishDiesel
          Howdy folks,
          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
          10-30-2021, 12:47 AM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • c_corr
          Asus P4C800-E VRM issues
          by c_corr
          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
          This board uses mext ICs and Mosfets in VRM:
          - ADP3180 PWM controller - in 3 phase mode
          - ADP3418 as Modfet drivers
          - High side Mosfets STD38NH02L (from ST)
          - Low side Mosfets STD90NH02L
          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
          02-08-2025, 11:59 PM
