Damaged through-hole via
  • yyonline
    • Jul 2009
    • 692
    So I was replacing a set of primary filter caps in an amplifier PSU board. The caps were glued to the board, and when I finally got them loose, I realized I damaged one of the vias when trying to break the glue bond. The trace is still good, but the via is not.
    My plan is to bypass the trace, and solder a piece of wire between the capacitor leg and the next component.
    However, since this is inside a sub enclosure, its possible the capacitor leg may make intermittent contact with the trace or what's left of the via from vibrations. Do I need to worry about arcing at all from this intermittent contact? This is a 200V 820uF capacitor and 125V mains voltage runs through it.
    I don't usually work with things outside of PCs, so I figured I'd post this and let one of the gurus chime in.
    Thanks!
  • japlytic
    • Oct 2005
    • 2086
    Re: Damaged through-hole via
    Do you have any pictures of it?
    I fixed a broken via in a UPS on a large snap-in electrolytic capacitor without any problems.
    Before I fixed it, the UPS inverter would not run, because the protective circuitry timed out because of a missing output rail.
    • digge
      • Apr 2006
      • 296
      Don't know exactly how it looks, but shouldn't you be able to fix it with some hot glue? Maybe get some thick tape to insulate where you don't want it to touch?
      • chth96
        Is it possible bridging tiny broken trace
        by chth96
        When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
        cutting tiny trace.
        This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
        Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
        But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
        12-03-2022, 11:32 PM
      • XxMicroSoldering
        ASUS Rog Strix G17-712LV Laptop Liquid damaged
        by XxMicroSoldering
        Hello Guys
        I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
        10-17-2024, 10:45 AM
      • Tomylee
        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
        by Tomylee
        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
        I'm looking for help with the following:
        The exact identification or part number of the T5 component
        05-28-2025, 12:42 PM
      • Friend4Cap
        Tuf gaming b550-pro damage circuit trace help!
        by Friend4Cap
        If anyone can help it will be very appreciate!!
        Motherboard - (TUF GAMING B550-PRO) client connected Floppy Drive 4-Pin Power Connector to RGB_Header_1 +12V G . R . B and Burn one N6V8 and Damage all circuit trace, please check pictures, Motherboard not turning on & everything check ok, no short to ground, I need to repair all circuit trace and replace burn N6V8 but don't know where this 5 circuit trace connect to N6V8. If anyone with TUF GAMING B550-PRO can check. “Thank you in advance”...
        05-07-2023, 05:38 PM
      • re-atari
        Gigabyte GA-H110-D3A schematic/boardview needed
        by re-atari
        Hello all,
        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
        02-24-2025, 06:45 PM
