Minimize resistor-generated noise in automotive multimedia
  • PeteS in CA
    • Aug 2005
    • 3576
    • USA, Unsure of Planet
    By Yuval Hernik, Vishay Intertechnology
    Courtesy of PlanetAnalog
    (01/30/2006 10:12 PM EST)
    Professionals interested in the quality of sound reproduction typically have a β€œtrained ear” which is sufficiently perceptive to detect the insertion of noise and distortion of the original signal. The resistors in the preamplifier, audio amplifier, or volume control of a sound-reproduction system often cause these undesirable effects.
    Audio noise generated by resistors results from the motion of electrons within the resistor, which creates an unwanted AC signal which gets superimposed over the primary DC signal. This type of noise falls into two categories: thermal noise and current noise.
    This has some good info on resistor construction.
    PeteS in CA
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
  • courtcircuit
    Philips HTS8000 home cinema noise problem
    by courtcircuit
    Hello
    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
    Removed each of tyhe boards
    02-08-2025, 08:22 AM
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
  • LEONARDO DE FREITAS
    Chinese multimedia crashes on the home screen, could someone help with the software or factory reset?
    by LEONARDO DE FREITAS
    Hello everyone, I have 2 multimedia systems with a 9-inch screen that turns on and only stays on the Android screen. It is very likely a software update. I have 2 software programs here but the multimedia system does not start the installation. Has anyone encountered this problem? I would be grateful if you could help.
    04-18-2025, 09:58 AM
