Just a good old Hard Clear?
  • alexanna
    • Mar 2010
    • 1346
    I think anyone that has read some of my posts, probably noticed that I come from an automotive background. I was very fortunate to do just the harder drivability problems, If I was stuck doing what we call” HEAVY WORK” in the automotive field I would have not stayed with it so long, even brake jobs were boring to me.
    One thing I noticed on automobiles when they started having several computers commutating back and forth is that sometimes things appeared to be in what I called the “Twilight zone” everything you checked looked like it was operating properly, But still there were issues. Chrysler products were really bad [Headlamps not working,Maby no windshield wipers or a problem with the HAVC blower motor.]After looking at the systems with a scanner and being able to force systems to work there seemed to be no logical answer.
    99% of the time just a simple of what we called a “Hard Clear” of removing battery cables from the battery and connecting the cables together momentarily would correct the problem.
    I am really just starting to think about televisions, and it seems that a lot of things have to check out for the set to work.
    I wonder with the proper safety precautions observed, if something like that is ever done?
  • ash91
    Hp pavilion 15 not detect hard drive
    by ash91
    Hello gentelmen .... this is my first post and sorry for my bad english,
    so my proplem is my laptop keep losing hard drive even if i but the
    hard disk in the cady (the box that can replace the dvd rom with hard disk)
    when i turn the laptop on the massage that said no boot media found pop on
    the hard disk is fine and to be sure i try another hard
    i also update my bios to the last update
    the 5 volt is present on the hard connector on the motherboard
    the dvd rom work fine when i but a windows dvd in it
    also when i boot from flash...
    06-07-2023, 01:45 PM
  • irepair559
    Ps4 1215a hdmi diode readings good everything good but no pic??
    by irepair559
    PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
    01-05-2023, 12:32 AM
  • jasakl
    Panasonic Toughbook HDDs with hard drive encryption - how to reuse them?
    by jasakl
    Dear community,
    i have searched the internet but i dont found a working solution for my problem:
    I have about 150 hard drives (mostely from hitachi 160gb HTS543216L9SA00) from Pansasonic CF-19 MK3 Notebooks.
    All devices had a BIOS Password and HDD encryption enabled.
    Now i try to reuse the HDDs, but i cant format them. I already tried windows Diskpart with argument "attributes disk clear readonly" but it says "cant delete" and i tryed several partition and low level formatters (like partition wizard, AOMEI and Easus).
    But all of...
    05-01-2024, 02:41 AM
    Multifix 425-01 and 450-01 Rework Flux Datasheet
    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
    - No Clean Formulations
    - Low residue
    - Range of activity to deal with different component solderability
    - Halide free
    - Suitable for dispensing
    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
    Both products are supplied in syringes or cartridges for application by dispensing....
    10-07-2024, 06:02 AM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
