Driving linear fluorescent tubes using CFL ballasts...
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    I been playing with these self oscillating circuits for a minute now, lord knows I've fried my fair share of them... but honestly I don't care, new ones only cost a few bucks each.
    Basically, the answer is yes, it CAN be done! The proof is in the pictures...
    What you see is a hacked sunbeam 25 tubular cfl ballast I got at Fred's dollar store driving an F15/T8 15w linear fluorescent, mind you in broad daylight on a cloudy day. I paid a whopping $2.50 or so after tax was included.
    Getting the bulbs open is easy. Take a hacksaw blade (not the whole saw) and carefully go around the ring up near the top being careful to just barely cut deep enough to cut the plastic but not enter into the center of the bulb. If you do, you risk cutting the wire leads on the bulb and or breaking the glass. Takes about five minutes.
    Anyhoos, I'd love to post more at the moment but I'm a bit pressed for time. Everything is in the very early research stages, eventually I would like to be able to get one of those relatively low output cfl ballasts and boost the power output to a level that will drive a standard 48" tube.
    So far so good.
  • delaware74b
    • Apr 2009
    • 628
    Re: Driving linear fluorescent tubes using CFL ballasts...
    Be careful with electronic ballasts, even the CFL's. A typical ballast will output >500 Volts at 20-40KHz open-circuit voltage.
    A typical T8 lamp requires approx 280mA current regulation (voltage is the variable for fluorescent lighting). The electronic ballasts designed for instant-start T8's use a high voltage burst to start the lamp then limits the current.
    If you don't limit the current, the start cathodes will be destroyed in a short amount of time.
    I can recommend a good ballast to reverse-engineer that has good over-current protection and end-of-lamp life protection (and isn't potted with that awful asphalt material) if you're interested. (in the US)
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • kikkoman
      • Jul 2007
      • 691
      this might be of interest to you:
      http://www.pavouk.org/hw/lamp/en_index.html
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • caspian
        What Zener Diodes on a Linear Power Supply
        by caspian
        Dear members,
        I have a linear variable power supply with unknown brand name that I used for voltage injection.
        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
        In addition, I discovered that its zener diodes are defective.
        I can replace the burned transistors.
        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
        Therefore, I cannot replace the zener diodes.
        I do not want to test the zener diodes in a test circuit to discover their model or value.
        no schematics are available...
        05-26-2025, 12:38 PM
      • прямо
        Help me understand this linear supply circuit.
        by прямо
        Was looking for a simple CV CC linear supply to build and came across this one.
        https://oshwlab.com/svalentin544/lab...ply-0-38v-0-5a
        I etched the provided board design and populated it.
        The output voltage adjustment works.
        The output current adjustment however, doesn't behave like I expected it to be. If PR2 is going clockwise, the output voltage decrease. Adjusting R5 has no effect.
        I don't have a load connected to the output at all.
        ​​​Can someone explain how the current adjustment work?...
        02-17-2025, 11:09 PM
      • bilux
        uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
        by bilux
        I want to find a replacement for uP0109 8pins, and i found this parts:
        uP0109 is "2A Ultra Low Dropout Linear Regulator"
        RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
        FP6137C is "2A BUS TERMINATION REGULATOR"
        can replace uP0109​ by RT9199 or FP6137C ?
        11-01-2024, 12:00 PM
      • edugimeno
        Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
        by edugimeno
        Hi everyone!
        I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
        I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
        This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
        To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
        I respected the polarity, positive to cathode of protecting diode
        So provided all...
        04-18-2024, 01:15 PM
      • ferah831208
        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
        by ferah831208
        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
        03-18-2025, 01:18 AM
