Prom/eeprom
+ More Options
Posts
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Prom/eeprom
    I know, its not about caps..
    But, mabye someone can help anyway.
    When looking at the datasheet for an Atmel AT28C256 EEPROM (PLCC) it seems pin compatible with a normal OTP PLCC PROM. But, when using the EEPROM, my device is not working.
    Any ideas ??
  • japlytic
    • Oct 2005
    • 2086
    Re: Prom/eeprom
    The AT28C256 has a different pin configuration to a normal OTP PLCC PROM.
    However, an SST27SF256 (many time programmable) is pin-compatible with a normal OTP PLCC PROM.
    • kikkoman
      • Jul 2007
      • 691
      Re: Prom/eeprom
      check the voltage levels (supply and signal), they vary a lot between the different families.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • Rob Northen
        • Jan 2010
        • 137
        • Denmark
        Re: Prom/eeprom
        Thanks for the help!
        I'll look into the SST27SF256
        • SidneyCanadas
          93C46 and 93C56 EEPROM
          by SidneyCanadas
          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
          06-14-2023, 01:16 PM
        • Instafixx
          Macbook A2179 820-01958
          by Instafixx
          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
          I checked the Power Sequences below and found this -
          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
          05-20-2023, 05:19 AM
        • dmccul2698
          Pioneer DEX-P99rs "No EEProm " diagnostic code.
          by dmccul2698
          Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
          1). Understand the schematic and check the connections between the EEProm and DSP
          2). Check the functionality of the EEProm
          I don't know if this is the unit's problem but it's a place to start.
          I have little to no electronic experience...
          04-08-2024, 05:32 PM
        • cook
          HP Power Supply 6632A: Fast Mode vs Normal Mode?
          by cook
          FAST MODE vs NORMAL MODE
          I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
          I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
          06-07-2020, 05:32 AM
        • edgarmg15
          Damaged EEPROM on TV Vizio E320-A0
          by edgarmg15
          Hi everyone
          Iยดm trying to repair a TV Vizio E320-A0 that I found in the street
          The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
          The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
          So, Iยดm going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
          11-19-2022, 03:46 PM
