Need Power Supply diagram
  • burntfingers
    • Jan 2011
    • 148
    A customer does not want to repair this LCD set - Sansui SV3050LCD, because of a major power supply fault, and because the agent does not has the complete item in stock [said it is obsolete].
    The power needs substantial repair, but I have no diagram.
    The set is oldish, and maybe I will not be able to get the original parts.
    Anybody here with that set's PS wiring?
  • burntfingers
    • Jan 2011
    • 148
    Re: Need Power Supply diagram
    Does it mean I have no luck here?
    Any suggestions where I can get that Power Supply diagram?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      You aren't likely to find a diagram. LCD power supplies aren't too complicated, please post a description of the problem and we'll try to help you fix it.
      Some clear, focused pictures of both sides of the board, resized as close to 2000x2000 as possible and uploaded using the manage attachments function would help greatly as well.
      A working TV? How boring!
      • hexxer
        • 3
        If you can manage to know the Vout, just change it with 3rd party one
        • burntfingers
          • Jan 2011
          • 148
          These are the transistors for the power supply I need to repair [for the above LCD set], but I have not found any reference to them in my books. Don't even know if they're transistors - look more like ics or regulators, I don't know. All are stuffed up [short-circuited].
          • jetadm123
            • 2169
            First photo- devices are dual diode packs:
            Fairchild FYPF2010DNTU
            STMicroelectronics STPR1020CFP
            Second Photo- devices are mosfets:
            Fairchild FQPF9N50C
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              The third one in the first pic is a 10 amp 200 volt ultrafast rectifier. Here.
              The ones in the second pic - 500v, 9A, 0.85 ohm N-Channel mosfets. Here. That was easy. The two transistors in the first pic are going to take a bit of logic to figure out, i'll be back in a few minutes.
              Edit: jetadm123 was in before me. The FYPF2010 are 20A 100v dual Schottky diodes not transistors.
              • burntfingers
                • Jan 2011
                • 148
                Thanks very much, guy!
                Much appreciated help.
                Now, the problem is going to get them, because it appears Sansui does not stock them [here in Johannesburg].
                I would prefer to replace the PS board, but supplier [Sansui] informed that it is obsolete.
                The customer is no longer interested in repairing this unit, and has - in fact - already bought another set.
                Either I fix it or throw it away.
                [I would like to repair it to use as a monitor for other jobs.]
                What do you suggest?
                Last edited by burntfingers; 05-06-2011, 12:05 AM. Reason: Not Sanyo: Sansui, sorry
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  First step would be putting your location info in your profile. Second step would be to order from Digikey/Mouser/Farnell, whoever is more convenient to you. You'll find several equivalents on all three stores i mentioned.
                  • burntfingers
                    • Jan 2011
                    • 148
                    Thanks again, guys.
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • Andreas_de
                      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                      by Andreas_de
                      Hello!
                      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                      04-12-2025, 10:38 AM
