Electrolyics and Impedance/ESR
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Electrolyics and Impedance/ESR
    Originally posted by thisguy
    On a side note, when you guys remove the PCB of the power supply from the case, do you guys usually desolder the input wires? On my PSU, it seems like the only way to unclip the socket for the incoming AC line and the power switch is to pull them outwards (which is a problem because they are soldered to wires from the PCB). It seems a little awkward to desolder the joints where the lines meet the PCB because the limited space. And if I desolder the joint at the socket, I worried that all the X and Y filter caps soldered to the same joint will fall off and it would be a bitch to put back on. How do the pro's usually handle this??
    I usually snip them at the AC socket end then clean tin and prep them with the PCB out.
    Also desolder, clean, tin and prep the pins on the back side of the socket with the PCB out.
    The legs of the caps should be wrapped around the pins.
    That's enough to hold them in place while you resolder the wires.
    Just try it...
    The worse that can happen is you end up with a bad PSU,,,
    ,,, which is what you already have.
    Make sense?
    Mann-Made Global Warming.
    - Dr Seuss
    • thisguy
      • 19
      nice. I'll give it a try when I my caps get in. Thanks again everyone your help, patience, and bearing with me (especially PCBONEZ for your continued support)! I've learned so much. Now all I need to work on is getting all the glue off the caps and figuring out which solder joints go with each cap (the entire PCB back just looks like a glob of solder. : )
      • competition
        Replacing capacitors in Evga PSU
        by competition
        I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
        11-14-2025, 11:12 AM
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
      • TomGJ
        Genelec 8020C Bad capacitor
        by TomGJ
        Hi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
        Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
        The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for...
        11-02-2024, 07:45 AM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • Antonynl
        What are typical ripple voltages on a laptop motherboard?
        by Antonynl
        I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
        So I have two questions:
        1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
        2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
        Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
        12-09-2022, 06:51 AM
