Some useful information about fuses...
    I found this on the internet and thought that it might be of use to someone here. Dr. Leidecker works for NASA and wrote a NASA manual on fuses for spacecraft...
    > From: Henning W Leidecker
    Subject: Re: Tin whisker follow-up question
    Date: Wed, 12 May 2004 21:41:31 -0700
    Dear XXXX,
    I've done a lot of experimental and modeling work with the FM08 style fuses.
    Each contains a nearly straight metal wire.
    For currents ranging up to about 120% of the rated current, the link opens by
    "creep to rupture", but never melts. The element is held at each end under
    bending moments; the ends stay cool, and so the built-in stresses there never
    relax; but the middle of the link gets hot enough to creep open in tens of
    seconds, even when tens of degrees under the melting temperature. I doubt
    that this mechanism happens in whiskers --- they are just too flexible, and
    are not fastened at both ends (only at one), so there cannot be important
    bending moments acting to induce creep.
    For currents from about 120% to (very roughly) 300% of rated current, the
    middle of the link reaches melting, and this molten section is pulled by
    surface tension back onto the cooler stubs --- the opened fuse shows a pair
    of stubs with a melt ball formed onto each end.
    For a whisker, one end is well-rooted in the surface from which it grows,
    while the other end is "just touching" a surface at a different potential ---
    the contact pressure is small since the whisker is flexible. (I am thinking
    of the large-aspect ratio whiskers. I leave a discussion of the very short
    aspect ratio whiskers for another time.) With gentle contact pressure, the
    Hertz-disk of contact between the whisker and the other surface is small, and
    the associated contact resistance is high. So there might be important
    heating developed there, unlike the case for a normal fuse element. (But
    this is what happens during welding --- the tip of the welding element is
    usually tapered, so that it gets hotter than the rest of the rod.) So we
    might initiate this adventure by having the tip of the whisker melt, and flow
    into the surface --- then the contact becomes pretty good, and the whisker
    tip would cool, while the middle of the whisker would get hot (this is the
    part of the whisker that is most isolated now from the heat sinks at each
    end). The whisker would then fuse open near its middle, with melt balls
    forming on each stub.
    For a fuse that is hit with (roughly) 300% to 1,500% of its rated current, the
    link heats so fast that almost no heat escapes from the ends, and so most of
    the length of the link heats uniformly, and reaches the melting temperature
    at nearly the same time. (The middle does reach melting first.) A liquid
    metal is still a conductor (the resistivity increases by 1.2 to 2.0,
    depending on the metal), and so the liquid column continues to heat until
    some forces act to break this liquid metal beam into different parts.
    One force is gravity --- it is important for long thick wires like overloaded
    transmission lines, but it is not important for thin wires or whiskers.
    Another force acting on fuse links is built-in bending moments, and this may
    be important for a whisker that is bent into a curve by being compressed
    between two plates (the one the whisker is growing from, and the other at a
    different potential) that are approaching each other.
    But the usual force for fuse link (and whiskers) is surface tension --- this
    excites the Rayleigh-instability once the length of the liquid column exceeds
    the diameter of the liquid region --- the liquid "beads up" in to a set of
    balls. (You can see this in Boys' Christmas Lecture book on soap bubbles,
    reprinted by Dover --- excellent book!) Or in a lava lamp. Or in a stream
    of water. We see this in x-rays of fuses: we count the number of melt balls
    visible inside the fuse-tube to estimate the overcurrent.
    For a fuse that is hit with more than (roughly) 1,500% of the rated current,
    the continued heating of the liquid column gets the metal hot enough for
    evaporation to become important before forces (gravity, built-in, surface
    tension) can break the tube up and stop electrical conduction. So some
    material evaporates off the hot column. This decreases the cross section
    area, and concentrates the current into a smaller area (ie the current
    density goes up), and so the heating rate increases --- this drives
    evaporation faster, and this concentrates the current even more --- that is,
    the process accelerates and the filament "explodes" in a puff of metal vapor.
    (Modeling this requires attention to heat lost by radiation and also by the
    heat carried off by the evaporating metal.) For overcurrents near (roughly)
    1,500%, only the middle of the filament evaporates --- inspection of the fuse
    envelope shows this evaporated metal present in a band near the middle ---
    and this band does not extend far enough along the envelope to electrically
    connect the ends. For much larger overcurrents, almost all the length of the
    link can evaporate --- the metal band deposited inside the fuse envelope can
    now bridge between the end connectors, and the fuse will continue to conduct
    electricity. Indeed, about the same amount of metal is available for
    conduction after this evaporation as before! (Just its location is
    different.) Since this metal film is in intimate contact with the inside
    wall of the fuse envelope, it is much better able to shed joule heat into
    these walls, and so the rating of this "reborn" fuse is now substantially
    larger! This is why fuse specifications limit the maximum current the fuse
    is intended to interrupt. This is intended to prevent the fuse from being
    used under circumstances in which it would be reborn in a more robust
    condition.
    A whisker that is hit with a huge overcurrent (such as few hundred
    milliamperes for thin whiskers) will mostly evaporate, and the metal will
    deposit onto the line-of-sight surfaces. The deposited metal could provide
    conduction if the film now bridges between ANY conductors, either the
    conductors that launched the evaporation of the bridging whisker, or any
    other coatable conductor pairs (can you say, "Use conformal coating!" I knew
    you could.) Bridging depends entirely on the locations of the surfaces
    collecting the evaporated metal. The more distant a collecting surface is,
    the thinner is the deposited film: films thinner than roughly 1,000 A (=0.1
    um) begin to have resistivities substantially larger than bulk values, since
    surface scattering of the conduction electrons begins to become important.
    When thinner than about 30 A, then the deposited metal is probably present as
    isolated islands, and the resistivity diverges to infinite values. So you
    can stop worrying once collecting surfaces become distant.
    This presumes that the available voltage and available current do not ignite
    the metal vapor into an arc --- then things get exciting in other ways. But
    arcing should be impossible for potential difference under 6 volts. And the
    huge sustained arcs are impossible at less than 20 A or so. Your case seems
    perfectly safe from arcing.
