Mains Transformers
  • barry wilkins
    • Aug 2009
    • 172
    Mains Transformers
    Does anybody have any info on the impedance and inductace of mains transformers ?
    I did some rough calculations on a 100va transformer kit with a 240v primary ,it had a turns ratio of 4.21 ,this would make the primary turns close to 1000.
    According to info on Wiki. the impedance of a transformer is N squared.
    This equates to 1MegOhm ,using 2x pi x f ,I got about 3.2 mH.
    This seem a bit high to me ?
    Any help with this query would be appreciated.
    Barry Wilkins
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Mains Transformers
    There are meters for this you know. Inductance depends on the magnetic material used, there is no general formula.
    A working TV? How boring!
    • barry wilkins
      • Aug 2009
      • 172
      Yes I know you can ring transformer to see if it has shorted turns,some meters for flyback transformers work like this.Not sure you can do it at 50hz though.
      Checking an old transformer about 200W gave an inductance of 0.7 mH ,so the formula Z=N2 is way out ,so perhaps you need to divide it by a reluctance factor .
      Barry Wilkins
      • lifthanger
        • Dec 2010
        • 10
        This is almost impossible to calculate because you'd have to know the exact permeability of the core material. This can vary a lot. According to Wikipedia ferrite has values ranging from 4 to over 10000. In Physics we always calculated with a given permeability noone told me I'd be licked in the real world .
        • learnmore
          Help choosing replacement transformer for Levoit 600S SMPS
          by learnmore
          Hello Community,
          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
          Peace
          LM...
          11-04-2025, 09:35 AM
        • amelbye
          is it ok to replace a dual output transformer with two single output transformers?
          by amelbye
          Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
          Now that's a challenge - luckily...
          08-21-2020, 08:51 AM
        • ohren
          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
          by ohren
          Hello!
          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
          Measured voltages with no load:
          After rectifier diodes
          12V: 6.17 V
          5V: 5.67 V
          Secondary transformer pins AC measurement (really don't know if this says anything)
          12V: 2-2.5 V
          5V: 1.04 V
          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
          03-18-2023, 10:33 AM
        • dicky96
          Laminator blows fuses and trips the mains - but not when on my ispolation transformer
          by dicky96
          Hi guys
          So here is a 'weird device' it is an IKON IP-450 A2 Paper laminator
          The customer says it was warming up then suddenly tripped out the 220V mains
          He replaced the 5A fuse which had blown but it did the same thing straight away as soon as powered on, it trips out the power in his apartment. He tried another power lead and tried it at a friends address but the same occurs
          So he brought it to me, having fitted a new fuse again.
          I plugged it in and it worked fine - it was drawing about 3Amps and warmed up to maximum working temperature...
          05-26-2020, 05:24 AM
        • mikey5791
          Is it possible for transformer substitution?
          by mikey5791
          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
          My questions are
          1. How do i test to see if the transformer is in good working condition?
          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
          Hope you guys understand what i was asking. My intention is...
          11-03-2022, 02:11 AM
