Running Quad Output Inverter in Parallel for One output?
  • Spode
    • Dec 2010
    • 41
    I have a TV that uses 2 higher power lamps using a slave/master unit that has stopped working. I have some sacrificial inverters from a TV that uses multiple lamps per inverter.
    Could I wire 4 outputs from one inverter to power a single lamp with the power it requires, or would this cause issues with the IC chip?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Running Quad Output Inverter in Parallel for One output?
    It would most likely just go into protect mode.
    A working TV? How boring!
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
      Corsair CX750M [Model 75-002019] - burned output toroid inductor
      by momaka
      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
      09-19-2021, 08:44 PM
    • organman
      Sharp LC-60LE633U Inverter output voltages
      by organman
      Greetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
      Thanks...
      03-22-2023, 06:47 PM
    • organman
      Sharp LV-60LE633U inverter output voltages
      by organman
      03-13-2023, 06:48 PM
      HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation E5430 Specification for Upgrade or Repair
      This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
      09-12-2024, 03:36 PM
