Polystyrene Capacitors
  • Agent24
    I see dead caps
    • Oct 2007
    • 5008
    • New Zealand
    I'm thinking of making a project (or two) that specify polystyrene for some capacitors.
    A quick look shows up Farnell has at least one value out of stock, and the price rather high anyway.
    I don't really know much about polystyrene capacitors, what was the reason for their use, and their disuse now?
    I assume some new capacitor type came along that was better... but which one?
    Is there anything I can use as a substitute or do polystyrene capacitors have some special properties that nothing else can match?
    -David VanHorn
  • japlytic
    • Oct 2005
    • 2086
    Re: Polystyrene Capacitors
    What project(s) are they?
    Polystyrene capacitors are usually chosen for applications requiring tight tolerance coupled with high stability. The temperature coefficient is predictable when used in conjunction with particular ferrite cores to make highly stable tuned circuits or oscillators.
    • larrymoencurly
      • Oct 2004
      • 960
      Be careful about ordering styrene caps in the summer because their max temperature rating is something like just 60-65C, even in storage, and a vehicle parked with the windows rolled up on a hot summer day can ruin them. I don't know if polycarbonate or polypropylene caps are a practical alternative. You may want to search "dielectric absorption", audio websites, and websites about A/D converters.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5008
        • New Zealand
        First project is the capacitor meter from Silicon Chip. The ones I need for that are in stock, so it's OK. I think I will definitely use them to ensure it works as it was designed.
        The other project is an induction balance metal detector from ETI (Project 549)
        I am not sure how critical the use of polystyrene capacitors is in that circuit.
        Would it help if I scan and upload a PDF of the article?
        -David VanHorn
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • Cama
          Solar Inverter - SMH-II - 2 missing capacitors
          by Cama
          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
          My model is : EASUN SMH-II 7 KW
          Mother Board : P/N 18947-002401250250
          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
          Thank you...
          09-12-2025, 02:50 AM
        • Ady2017
          Are there any datasheets available for Elna RJG capacitors?
          by Ady2017
          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
          05-25-2025, 02:19 PM
