Low ESR vs Low Impedance
  • bigbeark
    • Jan 2010
    • 661
    I note that Mouser has selections for "Low ESR" and "Low Impedance" capacitors on their site. The caps they identify as "Low ESR" are Panasonic FR series.
    When I look at the spec sheet, it states "FR has same low impedance as FM".
    I have read elsewhere that "Low ESR" caps are to be used in power supplies as they are less sensitive to high frequencies.
    I note that most catalogs and spec sheets are likely to have a "max Impedance" column but ESR data are often not shown.
    I generally go for low-impedance high-riplle caps.
    Does Low Impedance = Low ESR?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Low ESR vs Low Impedance
    Yes.
    A working TV? How boring!
    • mockingbird
      • Dec 2008
      • 5484
      Here is what PCBONEZ will answer you:
      Originally posted by PCBONEZ
      Not ~really~ but close enough at 100kHz.
      Lets run an example cap through the math so everyone finally gets it:
      I chose a 1500uF 6.3v MBZ with ESR = 0.026 Ohms
      [Middle of the normal range of caps on mobos and Rubycon gives actual ESR in data sheet vs Impedance.]
      Z = Impedance
      C = 1500 uF = 0.0015 F
      ESR = .026 Ohm [squared = 0.000676 Ohm]
      ƒ = 100 kHz = 100,000 Hz [Data sheet standard.]
      p = PI = 3.14159
      10 nH = 0.00000001 H
      -- nH guessed as reasonable based on other reading. Is physical size dependent.
      -- Lytics range from 4 nF for an itty bitty to 34 nF for a beer can cap.]
      XC= 1 ÷ 2pƒC
      2pƒC = 2 x 3.14159 x 100000Hz x 0.0015F = 942.477
      XC = 1 ÷ 942.477 = 0.001061
      XC = 0.001061
      XL = 2pƒL
      XL = 2pƒL = 2 x 3.14159 x 100000Hz x 0.00000001H = 0.006283
      XL = 0.006283
      (XL - XC) = 0.005222
      (XL - XC)² = 0.0000273
      Z² = ESR² + (XL - XC)² = 0.000676 + 0.0000273 = 0.0007033
      Z² = 0.0007033
      Z = 0.0265
      Z is only 0.0005 different from ESR at 100kHz
      That's less than 2% different.
      "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
      -Leonid Brezhnev (On the Yom Kippur War)
      • bajdik
        Lenovo ThinkPad OCP and impedance of Intel i7-10750H
        by bajdik
        Hello, I would like to know if reading of 1.6 OHM on i7-10750H is too low or not.
        I can not compare - no other board with 10th GEN for measurement.
        Thank you very much for your help.
        08-09-2024, 03:38 AM
      • clearchris
        "Low Impedance" vs "Low ESR"
        by clearchris
        From my research, "low impedance" are pretty much the same as "low esr" caps except the "low esr" caps come in a smaller package. Am I reading this wrong? "Low impedance" caps seem to be much more commonly available (and cheaper) than "low esr" caps. I'm not afraid to lean over some caps if I have to make them fit because of size.
        I'm about to pull the trigger on a pretty large cap order (for me) and want to make sure I'm not buying the wrong stuff. I'm stuck in the house, busy working through my electronics projects, and it would...
        03-26-2020, 09:12 AM
      • BlueMonsoon
        How to find the spec of this TEI-16760-01-08C transformer.
        by BlueMonsoon
        Hi, I want to replace a transformer in a motor cycle battery and float charger, but I can't find any info or the spec of the transformer, in order to start looking.
        The number on the transformer is, TEI-16760-01-08C. The info on the charger is input, 220-240V 50hz 0.085A output 12V 0.8A.
        Does anyone know where I could find a replacement for this? Thanks.
        01-10-2022, 08:30 AM
      • Yousuf
        Acer Aspire 4830t, help with diagnostics PLTRST impedance
        by Yousuf
        Hi All,
        I have interesting diagnostics experience, with Aspire 4830t motherboard. All the voltage rails are up (except for integrated graphics, which I think happens later in the boot sequence). The PCH_PWROK and DRAM_PWROK are asserted. I can also see PCH reading the BIOS and fetching (and executing) the ME_Firmware. But I don't see PLT_RST# being deasserted (I always see it driven logic low). All conditions seems to be correct for platform reset but that signal is never driven high. Out of desperation, I changed the CPU and still see the same issue.
        Out of curiosity, I...
        11-07-2022, 10:24 AM
      • JimBanville
        Switched speaker impedance selector w/ Yamaha HTR-5740 RX-V450 powered on!! Problem?
        by JimBanville
        So I didn't realize there was a tiny written warning on the speaker impedance switch on the back that said moving the switch with the power on "may damage the unit". I actually switched it multiple times, listening for any possible audible changes. It wasn't until later I saw the tiny warning. I haven't noticed any issues though. Can someone please look at the schematic and tell me what damage I may have caused? Thanks!!...
        01-25-2021, 08:45 AM
