Akai LCT3285TA LCD TV power supply issues
  • charlz
    • Aug 2012
    • 8
    • South Africa
    Re: Akai LCT3285TA LCD TV power supply issues
    Please help me with the original values of these caps. EC14, EC10, EC9, EC20, EC19, EC18, EC25.
    the model number of the board is MLT169B REV. 1.1 2006.05.13[/QUOTE]
    Someone worked on this board before and I am not sure the correct values.
    • selldoor
      Slow Learner
      • 7870
      Perhaps post a good clear picture - ring & label the positions.
      Make a list of what caps you have in which positions now.
      What problems does the set exhibit.
      • selldoor
        Slow Learner
        • 7870
        DO NOT POST THE SAME QUESTION IN MORE THAN ONE THREAD
        Decide which one you want to continue with.
        • jokerusv
          • Oct 2011
          Could someone help me with value of R12 & R13 for the MLT169 ? The PS in discussion had bulged caps and these resistors burnt and unreadable.
          Many thanks in advance!
          • nico81
            • Italy
            Hello everyone, this is my first post.
            I introduce myself, my name is nicola and I write from Italy.
            I hope you can help me, I'm trying to repair a lcd akai modell lct3201ad and placed the power supply mlt169b rev 1.2.
            I replaced all the electrolytic caps, but I can not find the value of the ceramic capacitor C33 placed under the sink the mosfets q11. the code is illegible, and it broke.
            help me! thanks
            • Lythius
              • Aug 2014
              • 3
              • Italia
              #26
              q11 is FQP7N80C
              • Lythius
                • Aug 2014
                • 3
                • Italia
                #27
                C33 is 101K 1KV
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  Yesterday, 07:14 AM
                • CMCM
                  Russound CA4 Power Supply Repair
                  by CMCM
                  Hello Everybody,
                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                  The outputs marked 12v and 20v are all measuring only 1v.
                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                  The capacitors physically look clean (no bludgesor leaks) and...
                  07-03-2025, 01:12 PM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
