Akai LCT3285TA LCD TV power supply issues
  • charlz
    • Aug 2012
    • 8
    • South Africa
    Re: Akai LCT3285TA LCD TV power supply issues
    Please help me with the original values of these caps. EC14, EC10, EC9, EC20, EC19, EC18, EC25.
    the model number of the board is MLT169B REV. 1.1 2006.05.13[/QUOTE]
    Someone worked on this board before and I am not sure the correct values.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Perhaps post a good clear picture - ring & label the positions.
      Make a list of what caps you have in which positions now.
      What problems does the set exhibit.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        DO NOT POST THE SAME QUESTION IN MORE THAN ONE THREAD
        Decide which one you want to continue with.
        • jokerusv
          • Oct 2011
          Could someone help me with value of R12 & R13 for the MLT169 ? The PS in discussion had bulged caps and these resistors burnt and unreadable.
          Many thanks in advance!
          • nico81
            • Italy
            Hello everyone, this is my first post.
            I introduce myself, my name is nicola and I write from Italy.
            I hope you can help me, I'm trying to repair a lcd akai modell lct3201ad and placed the power supply mlt169b rev 1.2.
            I replaced all the electrolytic caps, but I can not find the value of the ceramic capacitor C33 placed under the sink the mosfets q11. the code is illegible, and it broke.
            help me! thanks
            • Lythius
              • Aug 2014
              • Italia
              #26
              q11 is FQP7N80C
              • Lythius
                • Aug 2014
                • Italia
                #27
                C33 is 101K 1KV
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  03-31-2024, 02:12 PM
                • CMCM
                  Russound CA4 Power Supply Repair
                  by CMCM
                  Hello Everybody,
                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                  The outputs marked 12v and 20v are all measuring only 1v.
                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                  The capacitors physically look clean (no bludgesor leaks) and...
                  07-03-2025, 01:12 PM
                • JimBanville
                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                  by JimBanville
                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                  09-13-2023, 07:21 AM
                • madan1
                  555 based power supply getting too hot
                  by madan1
                  Good day.
                  I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                  The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                  After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                  When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                  06-23-2025, 04:38 PM
