Re: Reversed polarity cap killed PSU board
If you pay shipping you can have it. I'd love to see you get it working again, and you can tell me what was wrong. I can ship Canada Post, wouldn't cost you more than $20, possibly a lot less.
Shame you're not in US, I'd ask you to send it to me.
OTOH: they are going for ~$50 with s/h on Ebay.
ToastLeave a comment:
Ok, I'm done with this one. Too much time, and I think I caused more damage when I was trying to measure +5V output and touched one of the other pins. Then I DID blow that "W" fuse underneath and now I get no reading.
In the rubbish bin this one goes.Leave a comment:
Don't worry, it's nothing. I took the entire thing out and when I was rocking it back and forth, the traces on the underneath came loose. It's difficult for me to pull things out which have more than two legs. It's no problem. Onward. Do you have any other suggestions?
Retiredcaps suggested I check the 5VDC output to the logic board. Thankfully it is marked. The third set of pins is +5V. I'm assuming one is positive and one negative. should I check if it is outputting +5v with the board plugged in? Should I measure the 5V from the PSU or from the logic board?Leave a comment:
"I had to lift the traces to get this thing out" wtf!?
On the lowest Ohm setting, I get 285 today. On two KOhms I get around 1.045. 20 Kohms gets me around 3.13. On 200Kohms, around 13.5. When I set the DMM to "2M" I get the aforementioned .004. I assume these numbers are meaningless, because I read that all a Ohm test on a diode can do is check for continuity in one direction and complete resistance in the other (Which shows it's doing its job).
I had to lift the traces to get this thing out (No worries, I'll bridge after). Here are the readings:
Speaker setting: 289
2K: 1.080
20K: 3.34
200K: 18.9
Reversing polarity shows no continuance. It looks like this diode tests good. Also there are no visible signs of failure on the diode. I am assuming you did not want me to test JUST the middle leg, correct?Leave a comment:
2 separate circuits. The other is not the one that was "shorted" by the reversed cap.
Readings only for the one I asked please - 004 or .004 ?
DMM with no diode check? Okay.
Try to unsolder just the center leg of the diode pack and measure it. Make sure it is not touching the pad at all. If you can't do that, you'll need to unbolt and unsolder it to measure it. If you get the same readings, then it is shorted and needs to be replaced, and is the culprit. Is there a crack on the surface where it is marked with its' numbers?
If this is good, then the problem likely is on the other side of the transformer in the driving circuit.
R107 & 108 are good. They are 2 - 200Ω resistors in parallel, so their resistance is 1/2.
ToastLast edited by Toasty; 11-12-2010, 04:30 PM.Leave a comment:
In that case the diode is good.Leave a comment:
Also, according to the datasheet the middle pin goes to the cathode. I read ~270 for the one you asked me to check and 310 for the one that's also screwed into the heatsink next to it. If I reverse the polarity, it just keeps climbing.Leave a comment:
I don't have a diode tester, I'm using Ohms to measure it so a low reading should be ok. The other rectifier also tests the same.
edit: I also want to make a correction. I stated in my first post that the cap I reversed was 10V 220uF. I mean to say 10V 2200uF.Last edited by mockingbird; 11-12-2010, 01:28 PM.Leave a comment:
That sounds like a short to me. If it reads 004 both ways around then it's definitely shorted.Leave a comment:
Fuse F102 tests good. Resistors R107, R108 show 103 Ohms (Don't I have to desolder them to test them?). Dual diode tests OK (I think), shows reading of 004. Markings on it are:
STPS10H100CFP
GK09P VW
CHN 643
And it has an ST Microelectronics logo on it.Leave a comment:
There are main fuses one of which is the black vertical cylindrical one near the plug which is 3.15a 250V. It shows continuity. The next is a glass horizontal fuse in the middle of the board. Also tests OK.
Here are some pictures someone posted in an different thread, so note that it is not my board, he hadn't recapped it yet. Very high resolution:
Top Of The Board
http://www.shadowhunt.com/images/badcaps/VG2021m-1.jpg - Two main fuses. One in the corner right near the power plug. Tests OK, and one in the middle of the board to the right of the four chips. Note: The two blue things to the left and right of the power plug... Either they're MOVs or resistors, forgive my ignorance. They do not show contiunity.
Bottom Of The Board
http://www.shadowhunt.com/images/badcaps/VG2021m-2.jpg
Two more he posted:
http://www.shadowhunt.com/images/badcaps/VG2021m-3.jpg
http://www.shadowhunt.com/images/badcaps/VG2021m-4.jpg
The large green Taicon capacitor to the right is the one I replaced with Panasonic FC but reversed the polarity.
Thanks for your help.Leave a comment:
I will post a picture later hopefully. But I wanted to ask you this... I tested all the picofuses, they all have continuity, but why do they have polarity? It should show continuity regardless.
If they are defective, should I just bridge it? It will be difficult to replace these little things. I would much rather install a regular fuse somewhere else on the board if I could.Last edited by mockingbird; 11-12-2010, 04:22 AM.Leave a comment:
Photo's of yours top and foil side, please. Model number of board?
There may be one or 2 fuses depending on the PSU model. They can be the regular cylinder type in ceramic or glass. There is a reddish colored "can style" that is popular, and sometimes a "pico" fuse that can appear as a small resistor or diode. All would -usually- be marked F something on the board.
No, the bulged cap is shite. In the bin with it. The rest of the caps are probably fine.
Find the fuse(s) and check it/them with an ohmmeter. The continuity check or lowest scale is perfect.
If there is 5V DC present on the connector, test the voltage regulators to see if they are outputting the correct voltages.Leave a comment:
I recently recapped an Acer AL2017 LCD. The monitor worked a few hours but then started clicking which I erroneously attributed to a coil. The monitor died completely afterward and there's no power. I opened it up and surely enough, I soldered a Panasonic FC 10V 220uF capacitor the wrong way.
I'm not sure where to go from here. I replaced it, but there's still no power to the screen. Something is blown. Is there a fuse I should be looking for or is it maybe the starter cap or the main primary?
Also, the Panasonic cap that was in the wrong way bulged slightly and is probably not good anymore. The other caps look ok. Do you think I should trust them or should I check their ESR?Tags: None
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
