Finding smd led to replace
  • matk
    • Oct 2023
    • 7
    I got this fuel indicator board that has one color of the circled led not working, do you know what kind of led is it (it measures approximately 2x3mm) and if it can be replaced with a soldering iron ?
    Do you also know the kind of the other four leds above ?
    Many thanks!
  • matk
    • Oct 2023
    • 7
    Re: Finding smd led to replace
    Nobody know what kind of led it is and if can be replaced ?
      • 21426
      How much voltage going into it, and what are the 2 colours supposed to be
      • matk
        • Oct 2023
        • 7
        The colours are green and red, don't know how much voltage probably not more than 5V, if needed to know I will try to measure it.
        The other four leds are all green.
        • redwire
          • 3912
          Can you measure the size of the LED. It is likely a plain bi-color SMD LED, guessing 3.0*2.5mm but there is bigger 3.2*2.7mm etc.
          example: Kingbright APB3025ESGC-F01
          Once you know the size, a suitable part can be found in your locale.
          A multimeter on diode-test can check if both LED's are working, or if the green one is 3.2V or 2.1V type if it is working.
          • matk
            • Oct 2023
            • 7
            The voltage on red led is 1.8V but strangely the voltage on green led is 5V.
            Do you believe it is normal or there is something wrong ?
            • jordanaudio1
              Samsung TV UN60KU6270F power supply
              by jordanaudio1
              Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
              My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
              07-07-2025, 07:38 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
            • RetroComputingGrotto
              Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
              by RetroComputingGrotto
              I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
              As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
              What is your advice/opinion on whether or not on old(er)...
              04-03-2024, 08:30 AM
            • Agx03
              Rog Ally Z1 extreme, Need help finding a resistor
              by Agx03
              I Need help finding this resisteor for a Rog Ally Z1 extreme. I cannot find one anywhere. RES 20m OHM 1W (0612) 1%//CYNTEC/RLM1632W-6F-R020-FNH-50 PRS8901
              08-14-2025, 05:00 PM
            • chth96
              Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
              by chth96
              I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
              Since then, This AC/DC adaptor have been out of order.
              But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
              After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
              And Is there any possibility that it will suddenly explode as well as to be out...
              12-03-2023, 04:40 AM
