BK Precision model 1472C Oscilloscope Intensity problem ??
  • guizmo1967
    • Sep 2022
    • 77
    I have an old BK Precision model 1472C that is working but not the intensity ?
    At connector P309:
    Pin 1 +5V
    Pin 2 when I turn VR2, goes from +.648 to +5.07V
    Pin 3 GND
    R356
    Pin 1 when I turn VR2, goes from +.648 to +5.07V
    Pin 2 no matter how I turn VR2, voltage stays at +5.7V
    All the resistors around are good, except maybe R355 that reads 37K instead of 48K.
    I also would like to know what TC302 (capacitor trimmer) is used for, because when I turn it, nothing happened ???
    See the attach file, you can read the voltage at each transistor.
    Thank you !
    • 31267
    Re: Oscilloscope Intensity problem ??
    your missing a lot of the circuit, post the whole schematic/manual
    • guizmo1967
      • Sep 2022
      • 77
      Here it is !
      • redwire
        • Dec 2010
        • 3912
        Re: BK Precision model 1472C Oscilloscope Intensity problem ??
        "Intensity Problem" what do you mean, it's dead, it's dim?
        Why do you randomly turn trimpots? Hint: that will not fix the scope and it's not smart at all, it makes a mess.
        Start by checking the power supply rails:
        +195V
        +145V
        +18V
        +17V
        +13V
        +10V (master rail)
        -10V
        +5V
        etc.
        If there is HV -1.9kV you will hear the crackle of static electricity when the scope is turned on or off. Do you see the filaments lit at the end?
        I would not blame the blanking circuit yet, the voltages look ok. D315 WZ-050 zener is 5.0V 500mW.
        • guizmo1967
          • Sep 2022
          • 77
          Like I said the scope is working, there is a line, it's just the intensity knob that don't do nothing when I turn it. I mean by intensity, the brightness of the line.
          If I turn the knob all the way to the left, the line should disappear and if turn all the way to the right, should reappear slowly to full brightness (intensity).
          All the voltages you mentioned are good.
          Why on one side of R356, I have 0.648V to 5.07V when I turn VR2 but Base of Q320 stays fixed at +5.7V ??????
          VR2 is the intensity knob !!!
          • redwire
            • Dec 2010
            • 3912
            Check the power supply voltages first before saying a stage is not working.
            Again it could be the +145V or +195V rail is low or too much ripple.
            IC204 TD3400AP is quad NAND gate but with open-collector outputs. Q319 is cascode. The whole thing is pulsed.
            I think CRT grid bias comes from the D311, D312 switch. C337 1uF 250V is ok?
            Don't mess with VR307 lol it's not the problem.
            • guizmo1967
              • Sep 2022
              • 77
              The board is out, I need to change R355, supposed to be 48K but reading 37K !
              I will post when I reassemble everything ....
              • guizmo1967
                • Sep 2022
                • 77
                The two neon bulbs (NE-2) N301 and N302 are there for what exactly ??
                I'm asking because they barely light up …
                Some voltage measurements:
                On one side of R349 +195V, the other side with anode of D313, cathode of D314 and collector of Q318 I get +63V.
                VR307, C337 and cathode of D313, I get +112V.
                In the service manual, collector of Q318 should be +80.6V ???
                All the other voltages on that Power Supply are good !!
                  • 31267
                  neons are used as spike/overvoltage devices,
                  the interesting thing about neons is they have infinate resistance between the pins till they reach strike voltage - usually 70-80v, then they look like a short
                  • redwire
                    • Dec 2010
                    • 3912
                    The neon lamps protect the CRT grid-drive circuit from static electric discharges during power up/down, and protect the CRT from anything that could overdrive the grid positive into being a plate.
                    The neon lamps are normally never on. I would check D311, D312, R346, C343 for leakage as well.
                    The -ve grid bias for CRT comes off that -ve voltage multiplier which appears to be low.
                    How is the focus? To see if the high voltage is in the ballpark for the CRT.
                    • guizmo1967
                      • Sep 2022
                      • 77
                      D311, D312, R346, C343 are good !
                      Focus working as it should.
                      I'm going to replace C337 (1uF 250V axial). The only one I have near those specs is a 10uF 250V radial, so I think it's gonna be fine !
                      • guizmo1967
                        • Sep 2022
                        • 77
                        I replace C337, problem not solved. I'm running out of idea !!
                        One leg of VR2 (Brightness knob) goes to pin 3 of IC204, I'm beginning to suspect that IC, what do you think ??
                        Maybe a transistor after VR2 is not good but I don't like replacing components randomly !!!
                        • guizmo1967
                          • Sep 2022
                          • 77
                          Well, I'm about to give up on that scope !! After replacing many components, that were probably good, the intensity knob still don't do nothing at all, the line on the screen is at full brightness !!
                          The intensity modulation (Z-axis) jack at the back is for as I understand it, modulating the brightness of the spot at specific time, correct me if I'm wrong !!
                          What I did is connect a 100k pot to this jack with a range from -24V to +24V, but nothing happened on the screen no matter how I turned that pot …
                          The service manual spec says 20 p-p minimum.
                          Am I testing the intensity modulation jack not the correct way ??
                          Please give me some help before I think of throwing that scope in the garbage ...
                          Thank you !!
                          • SolomonMan
                            Vintage BK Precision 1403 Oscilloscope....
                            by SolomonMan
                            All,
                            Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                            Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                            I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                            12-03-2023, 10:39 PM
                          • toti24
                            (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                            by toti24
                            dell precision m4600 laptop
                            i7 2760qm
                            8gb ram 750gb HDD
                            intel hd 3000 integraded and nvidia quadro 2000m
                            pleasea bear with me english isnt my language and ill try to be as clear as possible
                            note i live in mexico in a very small town..
                            thank you.
                            laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                            the brick happened when i was installing win 10 using usb.
                            used rufus and officia microsoft.iso
                            it finished copying files from usb...
                            03-06-2022, 08:39 PM
                            DELL Precision T3420 Precision i3-6100 Specification for Upgrade or Repair
                            This specification for the DELL Precision T3420 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3420 boardview and Precision T3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            09-12-2024, 03:44 PM
                            DELL Precision 3430 Precision 3000 i7-8700 Specification for Upgrade or Repair
                            This specification for the DELL Precision 3430 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3430 boardview and Precision 3430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                            DELL Precision 7071 Precision 7000 i5-9500 Specification for Upgrade or Repair
                            This specification for the DELL Precision 7071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 7071 boardview and Precision 7071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
