I ask some good person for help on "@" character and how to understand the indicated
  • gabri2211
    • Nov 2016
    • 14
    • Italy
    Greetings to all of you, as you will understand from the questions, I'm not familiar with electronic diagrams .... from theory to practice there is always an abyss :o)
    1 - I often find the "@" character in the electronic diagrams of laptops near the component and I'd like to understand if it indicates a component that may not be present in the real hardware execution or if there is a different explanation for the use of this @.
    2 - I write these examples:
    2S@ PC217 0.22U_0603_16V7K 16 volts (max) what does it mean 7K ?
    @ what does it mean the @ character ?
    GPU@ PC218 0.1U_0603_25V7K
    The 0603 it means the package?
    the 0603 package is used to classify both capacitors and resistors or there are different tables?
    Thanks to anyone who can answer
  • harp
    • Jun 2022
    • 570
    • Planet Earth
    Re: I ask some good person for help on "@" character and how to understand the indica
    I dont know entirely, but I will try to answer based on some kind of logic.
    Name-of-rail-or-signal@ schematics-and-board-name-of-component used-value ___ used-package(dimension) ___ designed for max voltage
    So, there is C217 capacitor with 0.22 uF capacitance (220nF)/16V in package 0603.
    In some type of package could be any component who can fitted in, so, in 0603 package can be capacitor, resistor, led diode, inductor... and so on.
    What means sufix @ prefix P and 7K on end I dont know. Some mark for tolerance maybe... or specific marking of that company, schematic...
    • tester272001
      • 91
      A picture os what you described might help if Harp's answer is not enough for you.
      • gabri2211
        • Nov 2016
        • 14
        • Italy
        Thanks friends, just for answering me - you already helped me
        I would like to try to insert an attachment to explain better...
        OK done
        you will see on page 41 in the captions LED3 and LED7 a resistor with the character @, the other without @.
        and on page 45 you will see PD3 - PR8 - PC6 with character @.
        For the capacitors, I'm a qualified electronic technician, and I know the differences and the values of the components quite well, but my limits concern these representations regarding the electronic diagrams.
        Sometimes I see 7k in capacitors, but also 8J or 6 as on page 47
        Probably as Harp says it will indicate the tolerance, but I wanted to ask you if you know of the tables that describe these values, after all, for the resistances I see that the % is entered
        Many thanks again to all of you, Harp and Tester272001 - and to whoever wants to answer me
        • harp
          • Jun 2022
          • 570
          • Planet Earth
          So, simbols with @, * or so, may have be ommited by manufacturer...
          Signals with # mean low voltage is active true (inverted).
          • gabri2211
            • Nov 2016
            • 14
            • Italy
            I think what you wrote too.
            thanks for your reply
            • mkdj
              MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
              by mkdj
              About me, my goal and the equipment I (don't) have:
              I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
              About my issue and my goal:
              A friend of mine has a MacBook Air M1 A2337 that does not...
              04-03-2025, 08:28 AM
            • ugamazing
              820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
              by ugamazing
              So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
              1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
              2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
              04-10-2024, 08:06 AM
            • Rayblaster
              HP RP7 RP7800 from 2012/2013 worst fault - has "character"
              by Rayblaster
              Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
              I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
              12-30-2024, 06:28 PM
              TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
              FF Series (Very Fast Acting), 0603 Size
              Features
              ● Very fast acting at 200% overload current levels
              ● Low DCR
              ● High inrush current withstanding capability
              ● Fiberglass enforced epoxy fuse body
              ● Copper termination with nickel and tin plating
              ● Halogen free, RoHS compliance and lead-free
              Applications
              ● Notebook computers and tablets
              ● Digital cameras
              ● Memory cards
              ● Toys
              ● Bluetooth earphones
              ● Portable electronic devices​...
              10-07-2024, 05:50 AM
            • samoelec
              Trying to understand how to find best replacement cap for old parts.
              by samoelec
              Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
              Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
              The power supply board is exactly the same from this post so I'll just steal it for now.
              I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
              04-01-2024, 03:39 AM
