Ective Si152 fault
  • Achim64Germany
    • Feb 2015
    • 30
    Ective Si152 fault
    hello,
    i hope you can help me. on Place G29 (see black circle on Foto left) there was an short circuit and i can`'t read anyone.
    at the ciruit board are some D882 and B772 but i have no idea what ist built on this place 29G . I see there is the power current input
    who can help me please
    thanks Achim
  • lotas
    • Jan 2016
    • 4584
    • Russia
    Re: Ective Si152 fault
    D882 - 2sd882
    b772 - 2sb772
    • Achim64Germany
      • Feb 2015
      • 30
      thank you but which was on place 29G ?
      • Achim64Germany
        • Feb 2015
        • 30
        B772 ?
        • Achim64Germany
          • Feb 2015
          • 30
          no one ? who can help me please ?
          • redwire
            • 3907
            better picture please
            • Achim64Germany
              • Feb 2015
              • 30
              ok
              • Achim64Germany
                • Feb 2015
                • 30
                i can't add fotos at the moment ??
                • Achim64Germany
                  • Feb 2015
                  • 30
                  ok now
                  • redwire
                    • 3907
                    Do you mean V29? Looks like a SOT-89 package, a LDO. But what voltage?
                    Looking at the pinout, out-gnd-in would be OK with a 78Lxx. Not A1117.
                    You have to figure out the voltage of that regulator IC.
                    The SOIC below has no markings on it. Is it a MCU? Then wild guess, 78L05.
                    • Achim64Germany
                      • Feb 2015
                      • 30
                      thank you , i wood looking at this
                      • Achim64Germany
                        • Feb 2015
                        • 30
                        hello its a bc946.
                        Who knows the smd code ??
                        i didn't find it online.
                        • Achim64Germany
                          • Feb 2015
                          • 30
                          no one ?
                          • Achim64Germany
                            • Feb 2015
                            • 30
                            Originally posted by Achim64Germany
                            hello its a bc946.
                            sorry this is BD946
                            • Rictech
                              Panasonic SA-MAX770PU SMPSU board fault....
                              by Rictech
                              Hello everyone. 😀
                              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                              There are no devices that have exploded or otherwise show signs...
                              08-26-2024, 01:05 AM
                            • howardc64
                              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                              by howardc64
                              • Prior owner tried a replacement main board. No difference.
                              • Samsung 2x red blinking standby LED = panel fault
                              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                              07-19-2025, 10:54 PM
                              ESR meter came to the rescue again today with a PLC I/O card fault
                              by sam_sam_sam
                              I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                              I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                              One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                              12-18-2023, 08:17 PM
                            • cazi1001
                              Strange fault on Lenovo ThinkPad E14 Gen. 2
                              by cazi1001
                              I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
                              The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
                              On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
                              03-24-2024, 04:16 AM
                            • PanicMechanic
                              Extech EX330 multimeter current range offset fault
                              by PanicMechanic
                              My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
                              The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
                              As you can see from the pics, the offser is the same (just multiplied for other rages):
                              -4.9 uA
                              -0.49 mA
                              -0.49 A
                              I don't know what exactlly caused the fault.
                              The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
                              05-11-2021, 11:13 PM
