baofeng uv5r
    • 31267
    baofeng uv5r
    can somebody who has one tell me the belt-clip length and spacing between the screws in mm please.
    i want to put a belt clip on something else and uv5r ones cost peanuts on ali.
  • nervous_capybara
    Repairing the Hitachi DA-6000 CD player
    by nervous_capybara
    Hello everyone !
    I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
    Feel free to share your experience if you ran into other issues.
    DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
    CD tray would not come out of the player
    I could hear a motor spinning inside the player but the CD tray would not come out.
    Turned out that the issue was the CD tray belt that aged poorly and began to...
    11-05-2025, 03:11 AM
  • Babbar
    1980s Holz Her 2420 belt sander - Only works when speed control at maximum
    by Babbar
    My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
    11-13-2024, 01:54 AM
  • thesame
    Baofeng walkie talkie UV-16 PRO Mate not charging via usb type c.
    by thesame
    I use to charge it via type c and It stopped charging , with the usb c connected i measure 5V on the pins that are going to the battery , and on the working one i can measure 9V on the pins, after opening it i found this sot23 smd marking ACA9E burnt, and i don't know what to replace it with. Some people say it can be SY8008CAAC wich is a Synchronous Step Down Regulator others say it could be voltage detector like XC6114B545MR....
    09-17-2025, 09:33 AM
  • falcontech
    Aiwa ad-wx 717 belt measure
    by falcontech
    Hello
    Could someone tell me what size the drive belt of the aiwa ad-wx717 cassette deck is, I would like to buy it independently in my trusted shop, there is a kit online but I find the price exaggerated, unfortunately the original has practically melted. it is a double plate and the belts are the same, the one of the tachometer has remained intact thanks
    02-23-2023, 12:34 PM
  • abajor
    HP Pro Book 460 G11 Board DA0X8VMB8G1 REV:G Slow Clap for HP Bad ram shield to component spacing.
    by abajor
    Had someone drop off a laptop in which they were upgrading the ram but forgot to unplug the battery.
    Looks like the ram RFI shield shorted a rail going to or coming from a Silergy IC which blasted a component off the board. I'm going to assume it was a cap but really have no way to know for sure since this board schematic doesn't appear to be in the wild yet.
    I'm trying to identify the IC model now but it doesn't appear to match any of the Silergy codes from https://www.badcaps.net/forum/troubl...-tablets-and-m...
    11-01-2024, 12:50 PM
