nand flash was not detected RT809H
  • megatech27
    • Nov 2021
    • 8
    • Algérie
    please help me
    https://ibb.co/8477vKY
    https://ibb.co/RNzBLbt
  • DoOm86
    Swap nand flash smartphone for data recovery
    by DoOm86
    Hello everyone.
    I would like to know more about the following topic:
    Nand flash on smartphone for data recovery.
    I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
    But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
    How does it works? How do I know if data are encrypted or where is the key?
    I know there are also very expensive external socket where you can put the nand flash in...
    08-20-2023, 07:10 AM
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
  • mijatovic86
    JVC LT-32VF52K - Boot Loop - Nand Flash Steps
    by mijatovic86
    I have an issue with JVC LT-32VF52K, that is chassis Vestel 17MB110.
    It just flashes Logo JVC and then red led flashes for 12-13 times.
    Tried with flashing SPI MX25L1606 but acts identically with it also.
    How can I try and flash the NAND using only USB ?
    Can it be done with USB flash drive and usb_auto_update_A1.txt file, and what should be the content of that file ?
    I did find a nand dump on elektroda.pl, just need to be sure how to flash it ? Its LED JVC LT-32VF52K_NAND.BIN around 540MB large
    11-11-2021, 04:20 PM
  • megatech27
    i need dump of printer DCP-J562DW (NAND FLASH)
    by megatech27
    10-13-2023, 09:27 AM
