i need dump of printer DCP-J562DW (NAND FLASH)
  • megatech27
    • Nov 2021
    • 8
    • Algérie
  • spmetroil
    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
    by spmetroil
    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
    I have a CH341A programmer and I already attempted the following steps:
    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
    08-19-2025, 09:23 AM
  • kenzo2
    Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
    by kenzo2
    I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
    I need dump file MACBOOK PRO A2159
    TSB4232(256)
    TSB4229(256)
    Thanks​
    01-11-2025, 04:18 AM
  • Deeloc
    How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
    by Deeloc
    I have a 1tb WALRAM SSD (Photo)
    Controller SM2259XT2G (photo)
    Samsung memory (photo):
    Part Number K9DVGB8J1B DCK0
    Name V-NAND V6
    Type TLC
    The SSD itself is detected as 1gb, but is not initialized.
    There is a Sata to USB adapter
    A lot of SMI MPTool, did not flash it. compare flash fail (17)
    K9DVGB8J1B is not listed anywhere
    What to flash?​...
    06-05-2024, 08:32 AM
  • DoOm86
    Swap nand flash smartphone for data recovery
    by DoOm86
    Hello everyone.
    I would like to know more about the following topic:
    Nand flash on smartphone for data recovery.
    I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
    But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
    How does it works? How do I know if data are encrypted or where is the key?
    I know there are also very expensive external socket where you can put the nand flash in...
    08-20-2023, 07:10 AM
  • re-atari
    Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
    by re-atari
    Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
    Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
    02-03-2025, 06:49 PM
