Finally built the Bob Parker "Blue" ESR Meter
  • redwire
    • Dec 2010
    • 3912
    Re: Finally built the Bob Parker "Blue" ESR Meter
    I measure around 10mA idling, 25mA when testing, and under 0.1uA when off. It's a 5V device with LP2950 LDO (max. 30V in) and extra BJT power switch.
    Most important is the test current can be a decent 50mA narrow pulse (low average though) so it's not easily fooled.
    Here's some 4,700uF caps I tested with it and AN8008 readings for the laugh.
      • 31195
      so probably 15-18 hours of use on a full 500ma charge, not bad
      • jayjr1105
        • 281
        I saw spikes of around 35mA but about 12mA idle and 25-28 with the leads shorted or while testing a capacitor.
        Ryzen 3600x
        16GB Patriot 3600MHz
        MSI B450 Gaming Plus
        MSI Air Boost Vega 56
        Acer 32" 1440P Freesync
        Rosewill Capstone 750W
        Hakko FX-888D Station
        FX-8802 Iron
        MG Chem .8mm 63/37 RA 2.2%
        • volkswagenvan
          Volks
          • Mar 2009
          • 35
          Originally posted by Bob Parker
          So far I haven't heard of even one microcontroller failure due to connecting the Blue meter to charged high voltage capacitors. In fact the late John Bachman at Anatek who I collaborated with actually tried connecting one of the meters to bigger and more highly charged capacitors until it started blowing tracks off the PCB, but the microcontroller survived.
          I only designed the ESR meter to help with my own repairs. I submitted it to a local magazine as a construction project, and the editor gave me a look like "Why would anyone want to measure a capacitor attribute which no one has ever heard of?". But kit sales just exploded and have stayed high for 1/4 of a century.
          I'm sure that Andy at Alltronics who makes the kits now would help out if anyone needed a replacement microcontroller IC. He's that kinda guy.
          Blowing tracks off the PCB Wow! You had the hindsight to use special fusible link tracks! That meter was over engineered .Lol
          Cool story on the magazine construction project! I bet that editor understood a lot more about your project when your kit sales took off.
          Glad you have a such a good guy as Andy making up the kits for you and I feel a lot better about the longevity of my blue after reading your posts!
          Thank`s for all the information Bob and thank`s again for making the Blue!
          • Bob Parker
            Technician
            • Feb 2007
            • 182
            Thanks for the measurements. I don't actually have a Blue meter with me, and I was quoting the figures for the original Dick Smith ESR meter. I kinda forgot that the blue LEDs with their higher voltage drop reduce the meter's current consumption.
            It is a good shrubbery. I like the laurels particularly...
            • Bob Parker
              Technician
              • Feb 2007
              • 182
              You're the first person who's noticed the thinner "fusible" PCB track. 👍 Andy's doing his own thing with the Blue meters. My only involvement now is supporting people who build them and have a problem, and pop up on the Alltronics discussion forum.
              The editor quickly found out what the ESR meter was designed for, and even did a little article about getting one of the Dick Smith meters and using it!
              None of us ever expected it to become well known. It's been a surprising 26 year long "journey". 🙀
              • volkswagenvan
                Volks
                • Mar 2009
                • 35
                None of us ever expected it to become well known. It's been a surprising 26 year long "journey". ��
                I`m sure it will be around another 26+ years to come!
                • Bob Parker
                  Technician
                  • Feb 2007
                  • 182
                  That's if the Zilog microcontroller chips are still available. They're already being called "vintage" by some people.
                  • volkswagenvan
                    Volks
                    • Mar 2009
                    • 35
                    Lol, So am I !
                      • Jul 2011
                      • 6064
                      I have had mine for many years now and it still works very well in fact I just bought another one recently I going to take the first one and change it to run on 5 volts so when I check a lot of caps I do not have to keep turning it back on all the time
                      I also bought the ring tester as well and several times it saved my a** when trying to figure out why a switching power supply transformer end up being shorted and that why it was blowing the main fuse
                        • 31195
                        i built that ring tester on stripboard - couldnt have done without it fixing crt tv's/monitors!
                          12-31-2023, 06:04 AM
                          Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          09-07-2024, 05:00 AM
                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
