Prime95
  • sam67
    • 256
    Prime95
    Hi guys ,
    Any idea whats the best setting in prime95 when checking the rails on a psu using a DVM ...I want to give the comp a good load to see if psu values are correct when there is a full load on it.
    Just having a play around to get a better understanding thats all
    cheers
  • Wizard
    • Mar 2008
    • 2296
    Re: Prime95
    Torture mode test.
    Cheers, Wizard
    • sam67
      • 256
      Re: Prime95
      Thanks Wizard , will try it on that..all the best.
      • gdement
        • Jan 2007
        • 690
        Re: Prime95
        Torture mode isn't really a specific setting, it's more of a suite of settings that it rotates through. The settings that are actually in effect will be different depending when you check the readings.
        Probably doesn't matter though.
        • c_hegge
          • Sep 2009
          • 5219
          Re: Prime95
          There are three types of torture tests. Small FFT, in place FFT and Blend. I use In Place FFT to test a PSU as it consumes more power and puts more load on the it and use Blend to test a motherboard as it tests other things aside from just the CPU
            • 31012
            Re: Prime95
            do a scandisk too, or a defrag.
            get the harddrive doing stuff.
            • AJ847.63e
              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
              by AJ847.63e
              Hi Folks,
              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
              05-06-2025, 10:37 PM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
              HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
              09-06-2024, 10:56 AM
              HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
              HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
