Prime95
  • sam67
    • 256
    Prime95
    Hi guys ,
    Any idea whats the best setting in prime95 when checking the rails on a psu using a DVM ...I want to give the comp a good load to see if psu values are correct when there is a full load on it.
    Just having a play around to get a better understanding thats all
    cheers
  • Wizard
    • Mar 2008
    • 2296
    Re: Prime95
    Torture mode test.
    Cheers, Wizard
    • sam67
      • 256
      Re: Prime95
      Thanks Wizard , will try it on that..all the best.
      • gdement
        • Jan 2007
        • 690
        Re: Prime95
        Torture mode isn't really a specific setting, it's more of a suite of settings that it rotates through. The settings that are actually in effect will be different depending when you check the readings.
        Probably doesn't matter though.
        • c_hegge
          • Sep 2009
          • 5219
          Re: Prime95
          There are three types of torture tests. Small FFT, in place FFT and Blend. I use In Place FFT to test a PSU as it consumes more power and puts more load on the it and use Blend to test a motherboard as it tests other things aside from just the CPU
            • 31198
            Re: Prime95
            do a scandisk too, or a defrag.
            get the harddrive doing stuff.
