How to correctly desolder through hole IC?
  • Aliencomputres
    • Aug 2019
    • 218
    • România
    #41
    Originally posted by Aliencomputres
    Use Chip Quik REM4.5.
    https://www.chipquik.com/store/index.php?cPath=200
    • ktmmotocross
      recommend good solder wick on aliexpress
      by ktmmotocross
      I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
      02-08-2024, 12:48 AM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • silberdrache
      Burnt Hole under IC on MacBook Pro M1 Pro 14"
      by silberdrache
      I'm new to this Forum, so I hope it's the right place for this topic.
      Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
      I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
      The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
      I opened it up and there were only three drops of coffee...
      11-10-2025, 11:19 AM
    • corrize
      Best way to solder LVDS connector for beginner (and qfn) ?
      by corrize
      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
      See the test :
      https://youtu.be/bNAzC-EvqHs?t=1767
      With hot air from bellow the board, that's...
      03-09-2023, 02:57 AM
    • petemanuk
      BGA solder balls not connecting - help pls
      by petemanuk
      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
      11-16-2022, 05:21 AM
