Diagnostic card suggestion?
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hey guys, am fairly new to signal level troubleshooting.What diagnostic card would you recommend for laptop troubleshooting? Any other good piece of equipment I should have to help with troubleshooting PCH, etc?
    I have been looking at a few PCI diagnostic card but can't really decide which one would be more appropriate.
    This one keeps popping up with most search results:
    https://www.aliexpress.com/item/3282...archweb201603_
    Any help is greatly appreciated.
  • llonen
    • Sep 2014
    • 495
    • hampshire
    Re: Diagnostic card suggestion?
    In my professional work I don't find them particularly useful for diagnosis, but then most of my computer repair work centres around macbooks.
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      What kind of components/chips would I need to have in stock (besided having donor boards) if I wanted to start with macbooks?
      I guess the diagnostic card would be more helpful with non apple products then?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        In general, diagnostic cards are not useful in laptop repair.
        At the beginning, only have donor boards. then, you will find out what else do you need.
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          I actually would like to learn more about troubleshooting mostly North Bridge, South Bridge, PCH and CPU; hence my interest about getting a diagnostic card.
          Is there such a thing about a definite diagnostic for those (especially when it comes to a partially dead PCH, etc) or is it more of an "assumption/likelihood" based on measurement of signals?
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            since most signals are not transferred out of CPU/PCH, we have to diagnose based on assumption/likelihood sometimes.
            If you want to learn laptop troubleshooting, forget about diagnostic cards and watch a number videos on "laptop voltage measurement".
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              I did watch those a while back and learned quite a bit. Most PCH videos tend to be more reballing/replacement oriented though.
              So I guess am not getting a diagnostic card after all. Thank you for your suggestions!
              • llonen
                • Sep 2014
                • 495
                • hampshire
                You will find a good digital test meter indispensable, perhaps a decent storage scope although most switching frequencies to be found will be outside the range or most test gear. The other thing that will help you a lot is access to service manuals as they will contain information on component layout and test points.
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  I already have those; DSO, DMM, microscope, etc. Service manual/schematics & boardview is downloaded as and when needed.
                  • llonen
                    • Sep 2014
                    • 495
                    • hampshire
                    Then I am not really sure why you would need or want a diagnostic card(s) which represent a considerable downgrade over the test gear you already have. But if they are a must have for you then the one you have listed is cheap enough and probably as good as anything else on the market, buy it, play with it and then realise why they are mostly redundant. If there are any specific repair queries you have then post them up on the forum as these places are an invaluable source of information.
                    The other thing you might want to add is a logic analyser, again many of the data lines operate above the bandwidth of the cheaper logic analysers, that said I find one useful for the work I do with vintage computer equipment, you can of course use am oscilloscope as a partial substitute for an analyser to look at two or four data lines at a time.
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      I read somewhere (not sure if it was in this forum or somewhere else) that a diagnostic card would come in handy when troubleshooting PCH, etc. Hence my initial interest in getting one. Current pandemic kinda also make its not worth it getting one at the moment anyway due to shipping restrictions/delays.
                      Sure is! This thread being one of those quest for information
                      I do have one. A salae logic if I remember right. Haven't used it for a while now, can't properly remember its specs
                      • japlytic
                        • Oct 2005
                        • 2086
                        A number of new systems do not have PCI slots but have PCI Express slots; certain systems also output diagnostic codes via the SMBus available on PCI Express (and most PCI Express Mini and M2) slots.
                          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                          what is wrong with your PC in just seconds. It saves you time and money.
                          Our new and improved design...
                          11-01-2024, 06:29 AM
                        • gcrezz
                          GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
                          by gcrezz
                          The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the...
                          07-25-2024, 09:49 AM
                        • Kemer
                          Graphics Card mounting frame
                          by Kemer
                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                          What worries me right now is the possibility that...
                          09-14-2024, 08:57 AM
                          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                          09-06-2024, 08:30 AM
                        • FZG
                          EVGA Nu Audio Sound Card - Not Working
                          by FZG
                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                          I found...
                          03-07-2025, 11:44 AM
