Soldering Equipment Help
  • shimanole
    • Feb 2020
    • 8
    • US
    Thanks in advance for any suggestions.
    I've never soldered in my life but I'm committed to learning for multiple projects from LED strip lighting for floating shelves, to reworking and upgrading HiFi equipment.
    I'd like any recommendations for a soldering gun or station. I've looked at dozens and at this point I have no idea what to purchase. I'd like to keep the total cost under $150 if possible. At this point I'm looking at one of the t12 clones ShineNow, Bakon, Ksger or Quicko only because those tips seem to be highly liked across the soldering crowd. I'm open to any suggestions. (Edit) I just saw that 14 page thread on soldering stations. I haven't been able to find one of the Bakon950D's with the T-12 tips, only the T-13. If anyone has had luck with one of the other Chinese stations I would appreciate the feedback. I would still like any suggestions that may shorten the learning curve.
    I've acquired about 30ft of led strip lighting for practice so any suggestions for solder and/or any tips or tricks that might help me out early would be greatly appreciated.
    Thanks again!
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Soldering Equipment Help
    I recently bought a KSGER T12 and I absolutely love it. I can thoroughly recommend you buy one and several tips to go with it. I got the model with built in PSU so it runs on mains power (220V here). There is another cheaper version that uses an external 24V PSU but personally I don't see the point of it.
    So far I have been mainly using the BC3, BC2 and J02 tips but it will depend on what you want to do with it
    Remember to get a soldering iron stand and some 60:40 leaded solder. I would suggest 0.7mm and 0.2mm.. While you are at it also get some flux and desolder braid. That should all come well within your budget
    Have fun
    Follow me on YouTube
    Learn Electronics Repair
      • 31086
      dont buy the one with the aluminium handle - you need a nice rubber grip and not a smooth body that conducts heat!
      • shimanole
        • Feb 2020
        • 8
        • US
        Have fun
        Thanks Dicky for all of the information. What tip would you recommend for 10mm LED single color tape lights and audio amplifier repair.
        Probably a stupid question but when removing parts from an amplifier, is there a device to help remove a soldered connection?
        Also, is there a noticeable difference in ease of application between 60/40 and 63/37 solder? Thanks for throwing out the solder size also.
        • shimanole
          • Feb 2020
          • 8
          • US
          Thanks STJ!
            • Jul 2011
            • 6041
            Ksger soldering iron are great but if you are tempted to buy the one that is battery operated let give you a word of caution
            There are two different versions for battery operation and they are not the same
            One version seem to work good however the batteries that are used are not a well known brand name so the battery quality I cannot tell you at this time I have not done any testing on them yet
            I have plans to run some tests on them soon
            The other version has a very complicated BMS balancing protection board which seems to have some serious balancing protection issues ( not recommended to use this version until I figure out what the problem is )
            • shimanole
              • Feb 2020
              • 8
              • US
              Thanks for the info Sam. Just now looking at the Ksger units.
                • Jul 2011
                • 6041
                Here is the link to the one I would recommend if you are wanting a battery operated one
                https://a.aliexpress.com/_dZam1ab
                Choose set number “3”
                There is another option for using one of these units on battery power
                This option is a little cheaper ( for the battery pack only) but it does require some work on your part
                If you are interested in it let me know ( if you are interested in this option look at this post # 28 )
                https://www.badcaps.net/forum/showth...t=Ksger&page=3
                Here is the version of this soldering iron station that has a built in switching power supply
                https://www.ebay.com/itm/KSGER-V2-1S...AAAOSwLJdd9GKr
                Here is a version that is just the soldering iron station controller
                https://www.ebay.com/itm/KSGER-V2-01...EAAOSwsQJeCFNK
                There other options but they are little more expensive and are not compact
                If you are interested in other options let me know
                  • Jul 2011
                  • 6041
                  This is not a stupid question here are some solution to this problem
                  You could use Desoldering braids but I find that they are hard to use and not always do a good job of removing all the solder ( one note if the Desoldering braids are not new and or do not have enough flux on it then it is even harder to use it )
                  https://www.mpja.com/Desoldering-Sta...info/19034+TL/
                  Here is the link to the replacement gun
                  https://www.mpja.com/Desolder-Statio...info/17208+TL/
                  Here is the website page that has the spare parts
                  https://www.mpja.com/Desolder-Station/products/496/
                  I would recommend that if you have plans to buy one
                  I would recommend that you buy replacement tips this is a must have item on hand
                  I would recommend buying one replacement gun
                  I would recommend buying the replacement filters this is a must have item on hand
                  This unit works good for the money that you spending on it but the tips and filters do not last long
                  One note if you use the tip to bend component leads to straight them to remove the component the tips will not last long at all
                  • shimanole
                    • Feb 2020
                    • 8
                    • US
                    Great. Thank you very much!
                      • 31086
                      i have not worn out the tips on mine yet - dont put flux on the solder - it will eat the tip.
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        OK someone answered before me
                        It depends how much desoldering you want to do, how many 'legs' are on the components you want to desolder, whether you want to keep the desoldered part (or don't mind destroying it in the process as it is faulty anyway), and whether you want to work on through hole or surface mount or both.
                        For through hole desoldering I can recommend a soldering iron plus braid plus flux if you are not doing loads of desoldering and you want to do it on the cheap. Contrary to some opinions, this will do a very good job IF YOU DIP THE BRAID IN FLUX FIRST every time you use it.
                        Something like this
                        https://www.aliexpress.com/item/3293...archweb201603_
                        or even better this
                        https://www.aliexpress.com/item/3222...archweb201603_
                        and I swear by this flux for that sort of work. It is solid so you have to melt a groove into it and then dip the desolder braid into the groove. I have one tin of this and it has lasted me years already and I still barely used 10% of it. I am sure however that others here will have differing opinions on that
                        https://www.ebay.co.uk/itm/Electroni...75a35a570f5d2c
                        If you want to get a desoldering gun instead this will make it a lot easier and I can recommend this one
                        https://www.aliexpress.com/item/3298...archweb201603_
                        It's 90W and I am really pleased with mine. I've given it a fair bit of use and it has not clogged yet.
                        As regards the KSGER T12 I would say DO get aluminium handle! I have the black one, and the bottom part is like a rubbery sleeve, it is very comfortable to use and it does not get hot in use!
                        I have this one (the black one that has chrome ring and says KSGER on the side)
                        https://www.aliexpress.com/item/3300...archweb201603_
                        Because the holding position of this type of handle is a lot closer to the tip I find this much better to use than my old ZD916 which I still have. If you look on youtube etc you will see a lot of people swear by these handles. And believe me the T12 is a world apart from my older soldering station (which although it is not T12 it has almost the same handle as the cheap KSGER blue plastic ones so I do know exactly how the aluminium handle feels and, well, 'handles' compared to those ones)
                        https://cpc.farnell.com/duratool/d00...4aArKZEALw_wcB
                        If you want to do surface mount - and also this would be very useful for preheating boards before you want to desolder through hole components and and you find you are struggling to get enough heat from your desoldering gun (example removing faulty capacitors from motherboards) then get a cheap hot air station
                        I would recommend this one, which is about the cheapest you can buy
                        https://www.aliexpress.com/item/3271...archweb201603_
                        It is suitable for almost all desoldering work and I have had mine for years. Yes before anyone says, yes I do have a Quick 861DW and yes it is better than the 858D but it was 10x the price and I still am happy to use my 858D for this type of work
                        I hope this helps too
                        • shimanole
                          • Feb 2020
                          • 8
                          • US
                          Something like this
                          or even better this
                          This helps a lot. Thanks to all for the great advice. I think from a desoldering standpoint, I'm going to start with the station,braid and flux just to see how well I do with it. I haven't gotten into any of the electronics yet so I may need to do very little desoldering once I test everything. I'm going to look into the hot air soldering station for desoldering as well. Thanks again. Getting excited now.
                            • Jul 2011
                            • 6041
                            Look at this unit it work very well
                            https://www.mpja.com/mobile/Hot-Air-...info/34737+TL/
                            There are two versions of this unit
                            One the ZD-939A it alright but it does not show you the temperature that it is set at
                            This is my opinion and what I have found using one
                            This is a very nice unit and allows you to heat the circuit board where you want to desolder but have to have the right attachment for the job you are doing with the right amount of air
                            The other one
                            ZD-939L. Dose shows you the temperature that you set it and the temperature output
                            To me this is the better version and basically are the same price
                            This company sells both versions of this unit
                            • clearchris
                              • Dec 2013
                              • 687
                              I highly recommend getting some quality Sn63/Pb37 solder. Many people recommend the 60/40 and say it's easier to work with, well that depends. Generally, if I'm soldering, I'm also desoldering, and the 63/37 is FAR easier to desolder with. It stays molten longer so it's easier to suck out of joints. It also dilutes lead free solder better and with using less than you would if you were using 60/40.
                              Now if you can't help but wiggle components in the few seconds the solder takes to set up, go with the 60/40. Or, get both. But if you only have budget for one, the 63/37 is indispensible.
                              If you have the budget for it, a desolder gun is a true luxury. I have the Aoyue 474A++ Digital Desoldering Station and I don't think I'd ever want to work on a board without it again. I posted a review a few years back on here.
                              You should also invest in some chip quik. There are times when even the desolder gun doesn't do it, the chip quik really comes in handy, but it's expensive. Do not use it for soldering, only removing chips and components you just can't get out.
                              Edit: If you need a hot air station, I have been using a similar one to this and it has been great. I think I paid around $35 a few years back.
                              https://www.ebay.com/itm/858D-Hot-Ai...wAAOSwxuha9QcQ
                              Edit2: Don't cheap out and buy chinese solder. It works terribly, save yourself the trouble.
                                • 31086
                                this is good:
                                https://www.aliexpress.com/item/UANM...864986454.html
                                • dicky96
                                  Sun Seeker
                                  • Mar 2017
                                  • 1825
                                  • Spain
                                  Interesting that you have found chinese solder to be bad. The evidence suggests otherwise.
                                  https://www.youtube.com/watch?v=zZ9wxs6xuYU
                                  What problem were you having with the chinese solder?
                                  If you enjoy the above video, this one from the same guy is also worth a view
                                  https://www.youtube.com/watch?v=iKDAmY9Rdag
                                  Rich
                                  • clearchris
                                    • Dec 2013
                                    • 687
                                    Can't find the comparision I saw a few months back, but what he found was exactly my experince. The stuff clings to the iron, no matter how hot you get it. When you lift the tip, it always forms a needle peak right there. When it cools, it forms micro cracks on the skin that make the joint look 100 years old - dull grey, oxidized looking and bad.
                                    Maybe there are some good brands, but I have sworn it off. I do use mechanic solder paste and that seems ok, but I don't have anything to compare to. I also use kingbo flux and that seems pretty good, but will only be removed with brake cleaner.
                                    Just bought a pound of 63/37 AIM solder and I'm super happy with it.
                                    • shimanole
                                      • Feb 2020
                                      • 8
                                      • US
                                      Thanks again for all of the input. After opening a couple of my amplifier cases I'm definitely getting a desoldering gun. Can't imaging doing that kind of reworking efficiently without one.
                                      • SarcasticOP
                                        Seeking Guidance on Motherboard Diagnostics
                                        by SarcasticOP
                                        Hello everyone!
                                        I hope this is the correct place to post this, if not please let me know and I will post in the appropriate location.
                                        I'm venturing into the intricate world of board repair within electronics, and I'm reaching out to this community for some guidance and shared wisdom. I have tried to do some research myself and find this information on my own, but I don't know what I don't know, and that is really starting to become an insurmountable issue that I cannot overcome. The only person I had nearby that I could turn to passed away recently so I do not have anyone...
                                        01-10-2024, 03:35 PM
                                      • novice1
                                        Acer Aspire E5-574G - Not Powering On
                                        by novice1
                                        Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
                                        This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
                                        To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
                                        11-03-2023, 05:53 PM
                                      • aed040
                                        Tips when soldering U6960/TPS62180
                                        by aed040
                                        I am trying to fix my macbook.
                                        Can you give me some tips when replacing the U6960 chip.
                                        What Hotair temp and fan speed do you use?
                                        How long do you usually wait before you can remove a chip? Ive been watching repair videos and they can easily remove a chip after a few seconds but I've been heating the part on a test board for almost a minute and it wont budge.
                                        Does a really good flux help in melting the solder? I am not sure if my amtech flux is fake that is why its taking a long time.
                                        The flux is also being blown away from the...
                                        11-25-2022, 06:18 AM
                                      • Prott
                                        Soldering flex cable - tips & tricks
                                        by Prott
                                        Hello fellow badcappers,
                                        I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
                                        I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
                                        10-04-2023, 06:25 AM
                                      • bussincaps
                                        MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                        by bussincaps
                                        Hello All,
                                        tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                        Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                        eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                        Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                        I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                        08-03-2023, 12:57 PM
